Results 1 to 6 of 6
Hybrid View
    May 2010
    Default Delphi DCM3.4 galletto write problem
    Hi! I can't write renesas ecu Delphi dcm3.4 using galletto3. Read ok. In galletto manual i see support DCm3.4 with Renesas 64F7058 processor, but ecu have R4F70590. I try to write like 7059 but without secsess. May be i must use different resistor for 7059, not 560Ohm? Or i must write 7059 like 7058? OR galetto don't support this type of processor? need some hint... Many thanks!
    mislav88's Avatar
    Mar 2011
    galletto v53 can r/w this ecu obd
    May 2010
    Sure? -i see only "Megane 1.5 e3/4 delphi DDCR". its not old ddcr, its dcm3.4 ecu. My G3 is Eu-clone with 2012 soft inc renesas r/w. Maybe you meant Peugeot DCM3.4, like 407 2.0HDI?
    yes, for "write" i select other menu.
    LaraVAG's Avatar
    Jun 2011
    Poland
    In galletto there is other windows to read, other to write, check it,
    Piassini do it, if you have
    LaraVAG's Avatar
    Jun 2011
    Poland
    In piassini you have left menu and must select sh7059
    May 2010
    Quote Originally Posted by LaraVAG View Post
    i don't have piasini
