Results 1 to 3 of 3
    Feb 2008
    Default dreambox remote control to contol tv setup
    wanted to make my 7020 remote work the tv (change channel & volume ect ) found this thought might be useful to others
    copied from another forum all crdit goes to author
    "I got this very useful info from nikot04.
    You can control your tv-set using the DM remote control in the following easy to do steps.
    With your tv-set in use:
    1.Push the ?TV? button on your DM control once
    2.Keep the ?setup-SHIFT? button pressed until the red led of "TV" button flashes twice
    3.Type the code: 9 9 1
    4.Push the buttons ?Power ON-OFF? and ?TV? (in this sequence: first ?Power ON-OFF? and then ?TV? ) alternately until your tv-set switches off.
    You have to be patient with this step.In some cases you have to push this button combination up to 100 times.
    5.When your tv-set switches off push the button ?setup-SHIFT? once.
    With this step your remote keeps the code of your tv into the memory."
    you dont even need the tv code using this method just keep going until tv turns off took me about 25 goes
    Thank you! Very useful, Is working on Samsung plasma tv.
    Top Poster a1gunner's Avatar
    Nov 2008
    any body now the codes for blackbox 600 remote to control 32 samsung tv tried all codes no joy
