i have different information about this ecu, the database say : med17.5.0 with tc1766 tuning protected...is not possible work from obd...when you write TP ecu via obd you can throw away and change it.
i have use kess v2 read audi a4 2009 med17.1 2.0 tfsi read flash with obdii ok
after make tuning files, write to ecu,after ecu have kill,no can use,i use k-tag write same ecu number to bad ecu
write 128kb eeprom and 2048 kb flash,
is work,use diag, have 1 dtc,ecu bad!
what tool is can read full this med17.1 1796 mcu dump
friend,now what i do ?
ecu is bad,dump kill;
for what i know, you can only give the car at the dealer for buy new original ecu...I never had this problem.
I've never heard of anyone who was able to fix ecu TP blocked via obd...no one
I think new ecu is only option
or biy another ecu and make immo off
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
you can immo off,?
If you are interested i can perform immo off on your ecu
