Results 1 to 10 of 10
    Default VAG PPD Immo issue
    Had a car that had a bad DPF flash and is now ori.
    I flash mod file and car is in Safe mode, immo blocking start.
    I've attached e2p from BDM read. The car needs readapting I think. Can someone extract SKC? I don't normally get involved with immo stuff.
    What tool is needed to re adapt, AVDI?
    J
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
    fear_dark's Avatar
    Sep 2010
    your ecu security code : 8889
  3. The Following User Says Thank You to fear_dark For This Useful Post:
    J_amb_o (20th November, 2013)
    Thanks, this is what I got from AVDI earlier.
    I can log into Engine and Immobiliser using this code, but how can I adapt ECU to Immobiliser?
    fear_dark's Avatar
    Sep 2010
    with vas5054
    vas is ok? no channel 50 on ppd ecu?
    fear_dark's Avatar
    Sep 2010
    Maartinj's Avatar
    Nov 2010
    Better write corrupted backup and fix only damage flash area.
    Now you have Different VIN, CS etc dlat is why Immo is blocked
    of course you can easy do ECU adaptation with AN 037 Update from AVDI , but you need AVDI interface .
    I have fixed damaged flash area and written it back via BDM. Will try shortly.
  10. #9
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    i can rebuild this flash if you have problems. no need to touch immo
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  11. #10
    I've rebuilt flash, all working
