it depends on the serial you have..These two versions work different,and are activated differently.
Check your license if its for your serial.!
joji maroc (17th November, 2023)
Check it. But it worked on both for 6 months.
Sorry to hijack a thread but,is there a solution for autocom-delphi devices,that fixes the USB not Recognised problem??
Any hardware changes?
I tried eeprom 93c46 full of FF,not working,should i change ftdi chip??
I have many devices with this problem.
Hi. I have the same problem. I tried a lot of different fw, but every time when I remove the power and put again, it is just 4 red led lighting. I can flash with autocom od wow, and than it is working, but after switch ott and on again, just the 4 red led is again. How can I make it work? Thanks
When i had this problem i looked in device manager and found drivers only in one place. So reinstall drivers so it is seen in 2 places and all was good. Maybe i just got lucky.
Good morning, thank makadam's work, good job.
Sorry to refloat the thread, but it helped me to revive my old Autocom, I passed it from the 2013 to 2017 version, I hang the file that I got with the makadam procedure. I did not need to put the switch, only with the 1st bridge it worked.
a greeting
ilijakg (5th March, 2022), interceptor (1st May, 2022), joji maroc (17th November, 2023), mintika (29th April, 2023), roman66 (21st August, 2024), tomxx (2nd March, 2022)
Hi guys
I replaced my ds150e FT232 chip. After replacing it my VCI says "not found" message.
Before vci says found but did not update the firmware. It may be possible clone and it has got patatoes chipset.
Please who can anybody upload the FT232 settings obtained on Mprog or ftprog?
Merci :larmes de joie:
