Results 1 to 4 of 4
    Jan 2012
    Default focus 1.6 tdci dpfoff
    Hi I need confirm witch adress of dpf switch is correct in thise ecu
    - 1C8C79
    - or 1E735A
    can be by pm
    THANKS
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Hi ... see file ..no Fap
    resets data, in the dashboard, liquid fap, in order to eliminate error in engine
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  3. The Following User Says Thank You to centrohifi For This Useful Post:
    seba6772 (20th November, 2013)
    Oct 2012
    whether volta solution work ok on this car?
    Jan 2012
    Quote Originally Posted by centrohifi View Post
    Your dpfoff is ok but checsum not correct
