Results 1 to 15 of 21
    Oct 2011
    Default Launch Control in EDC16
    Hi mans. I need some help to activate Launch Control in EDC16. I saw solutions in bmw in a constant values changing the last(rpower thanks) Know launch control in vag edc15.. Also in this only have the "saw"map before gear dependant TL i tried setting 1 lower limit to 0 but it doesnt work.. who can help me?Hyundai i30 2.rar
    H.Wessel's Avatar
    could you explain how to make a launch contron in vag edc15? I want to make it to my car and I can not fine any solution yet.
    H.W
    Launch control in edc15 can only be done in edc15P PD vag engines...quite easy to do actually
    H.Wessel's Avatar
    yes only vag pd engines, I will takea look later
    Oct 2011
    Yes edc15p have a map. The rest of edc15c2 like psa some solution like this edc16. In gear ratio treashold. Who can help with this?
    BrunoPT's Avatar
    Oct 2011
    PT
    Quote Originally Posted by ominimicu View Post
    Wrong My Friend
    Look this video by vw golf 1.9 TDI 110HP VP engine
    Launch control can do in all units EDC15 VAG (Audi, Seat, Skoda, VW) the units support them.
    ohh i never looked into ohters i thought PD only thanks
    Oct 2011
    So anybody know what i have to do in first ratios? sometimes it block... only change under limit.. not the ratio treshold.. will test
    Nov 2012
    smartville in front of a OBDplug
    even on vp and old MSA ecu's ...
    Oct 2011
    So somebody can help me with this?
    Oct 2011
    Finally i found it. So thanks for all..
    Enviado desde mi HTC One mediante Tapatalk
  12. The Following 3 Users Say Thank You to herbon For This Useful Post:
    lumirb (18th September, 2024)
  13. #12
    hello, i have a3 2.0 tdi EDC16U1 and i try lot of test to implement launch control but the car is limit at desired launch revs only when the speed is more than 2km/h in neutral gear. for do that i change limit ratio to 0 and i limit the dependant Torque Limiter at desired rpm launch.. but why not limit when the car speed is 0. i post the orig file and the mod launch try, maybe anybody have a ideea and can help me .. thanks in advance
  14. The Following 4 Users Say Thank You to A3COSMIN For This Useful Post:
    delta rosso (9th August, 2018), lumirb (18th September, 2024)
  15. #13
    gomarota's Avatar
    would be nice know how to do on edc16 too, if you can share it would be great
    LOVE DK!
  16. #14
    spawns3's Avatar
    Portugal
    Quote Originally Posted by BrunoPT View Post
    Wrong My Friend
    Don't forget to tell that ecu already have a 29f400 and u can do it by OBD plug in old MSA ecus the launch control is not the same way.
  17. The Following User Says Thank You to spawns3 For This Useful Post:
    alfanacleto (7th February, 2017)
  18. #15
    gomarota's Avatar
    i attach file with launch control for edc16 for study, tested solution from other forum i dont remember name, would be nice to work together for have it working, i want to do in my car too.
    NO PASSWORD
    LOVE DK!
  19. The Following 8 Users Say Thank You to gomarota For This Useful Post:
    butchh (19th February, 2015), Daniel118355 (18th February, 2020), galiza (8th March, 2017), k1champion (9th November, 2014), LinusLinus (10th July, 2017), lumirb (18th September, 2024), Torpedo1996 (6th July, 2023)
