Page 24 of 37 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 553
  1. #346
    Feb 2017
    UK
    I have question for users of X6-V8 or similar. The problem is with cutting HU100 as groove width is about 2.90mm when the original blade has 2.62mm. Is there any settings for this? I try change some options but did'n see any difference. The problem is with some patterns cutting high at the very edge or even I had fixtue cut.
  2. #347
    Oct 2015
    Redliner - you can cheat it by assign higher cutter size than it really is and change y axis correction or cut depths correction. Try also cut from pc app, from my testing i know that programs in machine aren't good.
  3. The Following User Says Thank You to klesk1986 For This Useful Post:
    redliner (31st May, 2017)
  4. #348
    Feb 2017
    UK
    Quote Originally Posted by klesk1986 View Post
    I used machine PC software and change cutter setting form 2mm to 2.5mm also Y axis lowered for 0.15mm it definitely better I need to play with it but you suggestion was right. Thank You
  5. #349
    Jun 2011
    Perth, Australia
    Anyone tried cutting silca key CY24 for Jeep Cherokee?
    The machine ask to align the key to slot #4, but it only long enough to clamp to reach slot #3.
    It won't allow me to adjust from default slot #4 to slot #3 but can adjust further away to slot #5.
  6. #350
    Jul 2014
    Quote Originally Posted by redliner View Post
    https://www.youtube.com/watch?v=VLnDjwhzrIAI attached the photos of this product and I found a video with the same machine but is called different.
    I will decode all blades and compare the code for testing purpose. I think it may be the problem with the settings or loose parts in the machine because Chinese working fast and inaccurately in most cases. My machine was despatched DHL and I received after 2 weeks so I think they just made it from my money and they did not pay attention to details.
    hi buddy
    do you have a link or contact details for the seller of this machine?
  7. #351
    Feb 2017
    UK
    Hi You can find on Aliexpress but it's hard to find good supplier in there, many sellers write that they are manufacturer and give support but this is for marketing purpose or generic advertising just like with this video. I have problem with this machine and they did not answer after I send money. The android control is fiction - no one manage to set it up.
  8. #352
    Redliner,you have tu use a special vag vise to cut these keys,very cheap.
  9. #353
    Feb 2017
    UK
    Quote Originally Posted by dediegokey View Post
    Yes the Vag adapter was included to the set and I use it. I also buy additional adapter to cut Tibbe blade and just wonder if I need the one to cut Merc HU64 or not
  10. #354
    Feb 2017
    UK
    Quote Originally Posted by tkumonryu View Post
    Hi what machine you using ? did you try to use PC software ? there you can change key slot- see atached picture
  11. The Following User Says Thank You to redliner For This Useful Post:
    tkumonryu (21st June, 2017)
  12. #355
    Jun 2011
    Perth, Australia
    Hi Redliner,
    Yep, using the x6/v8 machine... Been using it without connect to computer... Looks like needed to get it setup connect to the computer. The software you showing is the codemaster5?
    Thanks for letting me know.
    Sent from my R7plusf using Tapatalk
  13. #356
    Feb 2017
    UK
    yes if you need drivers then let me know. The software in the machine is crap, don't cut properly, I had problem with HU100 some narrow blades as it's cuts very wide and VA2 cutting shape is completely different and some codes may not work.
  14. #357
    Feb 2014
    This is the miracle A5 software.
    redliner - without HU64 clamp you can't cut Benz blades
  15. #358
    Feb 2017
    UK
    Quote Originally Posted by autoTkey View Post
    Yeah I know there is a adapter for it but I was thinking that someone may try to cut this blade from ordinary fixture on upper site. I know that some people can cut hu66 without adapter but some have problems. I never cut Hu64 on this machine I want to prepare for this eventuality and ask users what they think.
  16. #359
    I just cut JMA MB7P with out adapter, loocks good, will try it tomorrow in the lock let you know if works.
    BDW Im using a Mirale A7 a clone from A5.
  17. #360
    Oct 2015
    I've also yesterday cut HU64 without any adapter (bottom, pos. 4) to S class 2003 and work perfect
