hello m8 , i have problem whit my v8/x6 machine . x sensor is gone , where i can find to buy it , search in aliexpress but nothing found . thanks in advice
I can find HU162 x8 profile to cut only one axle position from CodeMaster. I have key blade data dimension for HU162 x9 so just need to input into the software. X6 should cut properly on a original machine fixture like Miracle do. Problem is that both machines don't have data to cut Axis 2 with blade adapter. Cutting machine SEC-E9 can cut this key profile all way round.
https://www.youtube.com/watch?v=iIkLeGODer0
Have some replacements as well but last time that error was coming up I just pressed down on the sensor hard to try and close the gap area and error went away.
Anyone bought a replacement clamp for one of these? Will this one work if I take the clamp part and rails from the outer part? Heard that production on these has stopped and soon wont be able to get them any more.
aliexpress.com/item/32540551783.html
iozo (2nd September, 2019)
Hello. Where can I buy V8/X6? Anybody know some good sellers of this machine?
hello i need Manual parameter measure value calibration the v8 x6 key cutting machine in option machine clamp origin because i dont have key correction to i can do it in automatique option and when i can buy cupronickel like this video
https://www.youtube.com/watch?v=ky3x-0mR5UA&t=301s
X6 key machine
Does anybody actually run there X6 on the 12v system.
Be interested to know what 12v backup they use when out mobile and using as a portable device.
Someone get a used one for sale?
I use mine in the back of my van, uses very little power to charge or run.
Has any one tried making a profile to cut a kwikset key. The KW1 style. I'd like to get one made if someone can help me.
Here. Can use without single side adapter. Use the screws to clamp key and put tip to 5th slot, eyeball the key straight going down. You will probably have to adjust key center setting in code master down to get proper cut levels, everyone's machine is a bit different, -35 worked good for me, smooth turns. Unpack to your codemaster folder where the keys are stored.
I'd like to try the KW1 setting pretty soon. Has anyone else tried it?
I'm also interested in the HU100 X10 Cut version. Not sure if anyone has perfected it.
