anyone actually used one? seen bad reports about miracle a5 etc, so is this any better or worse? would like to cut keys from code but it's only a small part of the puzzle for me![]()
I use blitz framon viper and delta fo with multi copy carriage as well and have a bravo for copying
Silva have released a cylinder carriage for the viper now so it does laser and cylinder keys it's a little heavy 60kg but does the job well
I know someone that has ordered one. I'll see if I can have a play with it when he gets it and let you know
Automat (25th November, 2013)
Great stuff Badger. Thank you.
Bad reports on a5, you kidding me?
It's a beast!
fred77 (1st July, 2023)
A5 is great machine.
Sure few problems but nothing in comparison to the old days - it decodes![]()
A5 is a good machine , it may have had teething issues but support based on what users say is excellent , if i hadnt already had a viper id have bought one
Tony received his x6/v8 from onlyda today. Apparently he's cut an nsn14 and an hu66 so far and all working. I'll try and get over to have a look at it in the next few days and report back
that would be great if you could!!!!
I have been playing with X6 for the last two days.Does the same as the A5 but a lot cheaper to buy.The only fault so far is it will not decode VA2 or HU83 keys.Will cut them perfect if you input code but no decode .Have it working and running off laptop connected with USB cable.
If it is not too much too ask, can you upload few videos as well
Automat (30th November, 2013)
only want it for code work not duplicating or decoding![]()
hi
@a1locks: what software the machine uses to connect to laptop?
H.W
Hello
thanks for reporting about what is working because i think it is very cheap key cutting machine to buy
so pls advice to buy our no
Bought A4 had to adjust depth (cut on through to the other side (doors rip off). Friend got A6 for 1200 when A8 came out same machine A8 does new gm HS 10 cut pin 1 2 and 9 10 same. I have spent quarter of a million on equipment now a A6 used 1200, accureaders and lishis and a clone silca ad someone to teach you you in the game doing ford and cryslers for 80 bucks. Untill you get one you can not read pin or get it. When there where 6 chrysler dodge jeep in50 miles radius no problem pin. Now 1 tough luck. Learn eeprom/micro thats all I have been getting lately and others screw ups. They pay alot better.
