Results 16 to 30 of 38
  1. #16
    Faraday's Avatar
    May 2012
    The dark side of the moon
    No, I didn't
  2. #17
    May 2017
    argentina
    pass please!!
  3. #18
    May 2017
    argentina
    https://drive.google.com/file/d/1XXj...ew?usp=sharing
    immo off please!!
    porsche cayenne bosch 0621207696
  4. #19
    Mar 2019
    Ukraine Lutsk
    Bosch ME7 immo off
  5. The Following User Says Thank You to mazahacka92 For This Useful Post:
    TOPITOAUDIOCAR (16th March, 2019)
  6. #20
    May 2017
    argentina
    not start engine
    Quote Originally Posted by mazahacka92 View Post
    Bosch ME7 immo off
  7. #21
    Mar 2019
    Ukraine Lutsk
    Porshe have kessy system... This immo off 100% but not kessy off! Engine will be start but not from ignition lock. Try start engine from starter and make sure.
  8. #22
    Mar 2019
    Ukraine Lutsk
    In this car immo off bad idea. You must add new key to kessy.
  9. #23
    May 2017
    argentina
    only have motor and ecu not have kessy , i try emprom file but not work error code key
    i read eprom 5p08c3 gq4x4
    is porsche cayenne 4.5 v8 year 2006
  10. #24
    May 2017
    argentina
    memory says 35p08 3 could it be misread? with gq4x4 I read it as 5p08c3 it says, it reads and it writes well, but I read that it is a memory that the gq does not write it well, it has some secret? Should we put a new memory?
  11. #25
    Mar 2019
    Ukraine Lutsk
    No matter which programmer if veryfi ok... Photo ECU please.
  12. #26
    Mar 2019
    Ukraine Lutsk
    Is gq4x4 able to read or write 5p08?
  13. #27
    May 2017
    argentina
    gq 4x4 can read 5p08c3 / 95p08 but this is 35p08-3
    your file does not start, I put the old file back and start and shut down because it has no key
  14. #28
    Mar 2019
    Ukraine Lutsk
    Try this files. I think the second file will work.
  15. #29
    UK
    Can someone pls immo off this file from identical ecu pls.
    0261 207 696
    022 906 032 BT
    95p08 eeprom
    Many thanks
    if this post was usefull
    please press
    the thanks button
  16. #30
    May 2018
    Hello members. Please what tool can I use to read Porsche cayenne ECU?
