Results 1 to 8 of 8
Thread: File Mismatch
    Dec 2013
    Default File Mismatch
    When i try to update the channel list it just says file mismatch and nothing else?
    i have downloaded the channel list from DJ AJ listing any suggestions?
    Regards
    J4wdx
    May 2012
    Quote Originally Posted by J4wdx View Post
    Regards
    J4wdx
    Did you unzip the file?
    Dec 2013
    yeah i did unzip the file.
    DK Veteran bigade1's Avatar
    Oct 2013
    Check the name of the file. If you have downloaded the file into the same location as a previous version then it will have been renamed with a number added. If that's the case your box won't recognise it. It must be named TP_PROG.dbs only.
    Dec 2013
    done everything as stated but it keeps saying file mismatch and ive tried installing the older versions and now that says file mismatch too.
    Jun 2011
    It sounds like the file is corrupt when you try to download. Try Aj List direct from his site. http://www.ajsat.co.uk/
    Apr 2012
    What size is the file when it is unzipped as it should be around 1Mbit.
    I had issues with Internet Explorer downloading files used Firefox instead and this resolved the issue.
    Sep 2013
    May be stating the obvious here but have you changed the file type from Jpeg to Misc at the top of the page before trying to update?
