Results 1 to 6 of 6
Thread: skybox wifi
    Junior Member fishfinger's Avatar
    Nov 2013
    in a corner of s/w london
    Default skybox wifi
    any one else using the skybox wifi dongle
    i got 1 for ?5 seems to be ok saves running a cable across the frontroom
    only problem the 1 usb slot and in and out with the stick when updating channels
    tried a usb 4 way hub ,light on stick and on screen wifi connected but neither dongle or usb seem to work when plugged in any body esle had or having problems like this
    middots3's Avatar
    Feb 2009
    Middlesbrough
    Quote Originally Posted by fishfinger View Post
    I use one on my box in my bedroom and you just have to deal with it basically.
    The only thing that get's on my nerves is how ugly the box looks with the huge antenna hanging out the front of the box and how long it takes the channels to come on when you first turn the box on. Apart from those minor issues, it runs sweet.
    Jan 2013
    Well I have a very cheap usb splitter , not sure if it's the reason , but if I connect wifi dongle and flash drive , they stop working , if I try to record , I get disconnected ...
    I have a question though , when I connect the wifi on his own , it works well but if I switch off the skybox and back on , the box doesn't remember to connect to wifi , I have to switch it on in network setting every time , does that do it to you too ?
    Apr 2010
    I dont think the F3 / F5 has a big enough power supply to run a USB hub from it.
    Nov 2013
    ive tried 2 different hubs same thing.im gonna connect the cable back up,as you have to connect a usb for the 7day EPG and recording
    Nov 2009
    i would not try and use a usb hub in them it fries your usb drive what i read somewhere on net' wifi works just as good as hardwire in my opinion once its set up right' its just a mess on sorting it out wpa2 psk aes and wireless channel 1 or 6 works best on the router u are connecting it to.
