Results 1 to 15 of 16
Hybrid View
    Nov 2013
    Default sky box f5 channel list update
    hi, can anyone point me in the right direction, I have a sky box f5 and I have lost some of the channels of it, I don't know a lot about uploading new channel list to it and would like some help doing this from start to finish, firstly where would I obtain an up to date channel list in the correct order, am I better off updating the whole list or just the channels I have lost? if anyone can help me or point me to the correct thread it would be very much appreciated
    May 2012
    Quote Originally Posted by vwgolfs View Post
    Just stick AJ's list on. Its quite a simple job as long as you have a zip extraction program like winrar, winzip or 7zip.
    Save the TP_PROG file to memory stick or desktop then copy to mem stick.
    Box on any channel.
    Plug USB memory into box
    On your Remote Control:
    Press Menu
    Right or left arrow to Tools
    Press OK
    Scroll down to Upgrade by USB
    Press OK
    The Top Line needs to be changed to Misc Files by using right or left arrow
    Then scroll Down to Select & Upgrade
    Press OK
    TP_PROG.dbs should be highlighted
    Press OK (Places a tick at the end)
    Press Yellow Button.
    When finsished (100%) Press Exit, Exit,Exit
    Remove USB
    Box may reboot itself but if not power off and back on
  3. The Following User Says Thank You to DW190 For This Useful Post:
    kebabs2u (20th March, 2014)
    Nov 2013
    Hi DW190. Thanks for your reply, it looks quite straight forwards, can you tell me which list to down load with no adult content, there seems to be 2 of them without it? I have down loaded winzip, when I down load the correct list do I down load it to winzip and then on to my usb device? thanks for your help
    Hadron's Avatar
    Nov 2012
    E. London
    One of the files will contain duplicates of HD Film & Sports channels in SD as well (with SD), while the other one will not.
    Once you have installed Winzip it should provide you with a right-click context menu. So when you download AJ's channel list, just right-click on it & select "extract here" or "extract to" or something worded similar. Once it's uncompressed just copy & paste to your memory stick.
    If you prefer a Sky ordered list (same as you would get on a subbed Sky+ box), then download the channel list by sattv5.
    Dec 2013
    I've downloaded the channel list, put it onto a USB, plugged it into my F5 and updated but it comes up with;
    Upgrade None!
    Any ideas what im doing wrong?
    Mar 2014
    can anyone send me a link to the channel list ,i cant find it no were, i have a f5 skybox hd. many thanks
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by steviebeeuk View Post
    AJ's & sattv5's latest lists are in the sticky threads above.
    Mar 2014
    i spent all afternoon trying to open up aj's list,only for my 12 year old walk in take over and do it in 2 min!! i was trying to open it up instead of just sending to a memory stick,
  10. #9
    Member deano16's Avatar
    Jan 2013
    sheffield
    Are you selecting the right file on the upgrade file option and if the channel list file isn't named correctly it won't load!!
    Do as dw said and Download aj's list extract the file and then put it on usb stick then load into skybox
    Sent from my ThL W5 using Tapatalk
  11. #10
    Jan 2013
    sheffield
    Sorry when you choose select and upgrade are you selecting the correct file? That's what I meant!!!
  12. #11
    May 2012
    If it says upgrade none it could be any of a few things.
    Have you extracted the file with winzip or similar?
    Have you pressed ok to place a tick after selecting TP_PROG before pressing the yellow button?
  13. #12
    Dec 2013
    Ive wrote on somewhere else ive lost ch 5 hd and normal ch 5 and all box office channels are in someones fav list? Since i last updated think it was the 3rd dec ive got a f5s box. Think there must be another update due soon for the channel list. Well hope so mrs always watches ch 5 .
  14. #13
    Apr 2014
    Hi all, quick question. I have a Skybox f5 (clone) i downloaded the firmware update from: www.hddvbsw.com
    i would like a channel list for sky channels to be in some form of order. my worry is using a wrong channel list and bricking my box.
    can anyone suggest a update i can use?
  15. #14
    Jul 2012
    Aj's has an upto date channel list
  16. #15
    Nov 2008
    who is aj's ?
