Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
  1. #46
    Nov 2008
    Belfast
    You could have a well outta date satellite xml file, try updating it
    I very rarely scan the satellites now, just get the latest settings and ftp them to your box or download them from the images addons facility
    Try putting these on with DreamboxEdit
  2. #47
    Apr 2009
    Thanks for the channel list...I put them on using dreamboxedit...The channels that I can watch are the channels that I pick up with a scan...
    Sky premiere +1 (I can pick this up)
    SNR 81%
    AGC 90%
    BER 0
    Sky action (I cant pick this up)
    SNR 54%
    AGC 83%
    BER 65520
    this is pretty much same for all the channels I cant pick up...Any ideas?
  3. #48
    Nov 2008
    Belfast
    Think I am running out of fixes
    You could try another scan, if my file has newer transponder settings than what you were using b4 it may pick some up, my list is is a couple of months old so some channels may be on different transponders now, so if you scan then check for duplicates in the All Services List to see if its picked them up
  4. #49
    Nov 2008
    Belfast
    Here is the latest satellite xml for 28.2e just replace your own with this and do a scan
  5. #50
    Apr 2009
    Just to be sure, this goes in var/etc right?
    I put it in there and did a scan and picked up 60 more services (not sure which ones)...so I guess this made a slight change...
    When I do a scan should I keep no circ polariz. unchecked or shall I check it? I normally do a scan unchecked..
  6. #51
    Nov 2008
    Belfast
    Im not too sure myself, but if you just look in the settings file I sent you and replace the satellites xml in there with the updated one and then ftp it to the box with Edit it will put it in the correct place, then do a scan
    The newer xml has 62 more transponders
    The newer channels will be flagged after a scan
  7. #52
    Apr 2008
    When you do a scan check to see if its picking up channels from both horizontal and vertical polarities.
  8. #53
    Apr 2009
    I tried your suggestion...I got 42 new channels added...but still no where near all of the channels...
    It seems to be scanning both horizontal and vertical polarities...
    But all the channels that I cant receive have a high BER reading and an error saying service could not be found...This is on free channels as well like sky news...
    Could this problem be to a faulty box/tuner..? The box is about a week old..
  9. #54
    Nov 2008
    Belfast
    If you have another receiver handy, hook it up and see if it picks up any of the fta stuff your dream is missing
  10. #55
    Apr 2009
    I tried this and well...I picked up sky news and teachers tv...I cant view these on the openmedia box...
    I checked the signal strength on the fta box (old s*y amstrad box)...The strength bar is 75% full and the sig quality is 50% full...could this have an effect?
  11. #56
    Nov 2008
    Belfast
    Yes I think it could
