Results 1 to 11 of 11
    Default Doblo 1.3 Jtd DPF OFF
    Hi all..
    Fiat Doblo 1.3 JTDM 2007 ECu MJD 6F3.D1/HW03R/3058-D154
    I need remove DPF..
    many thanks!!!
    LaraVAG's Avatar
    Jun 2011
    Use swiftec, works great with this ECU
    Quote Originally Posted by LaraVAG View Post
    what swiftec ???
    Jul 2012
    Quote Originally Posted by zebbon View Post
    Hi all..
    I need remove DPF..
    many thanks!!!
    be careful that you have the file attachment on the forum is this:
    MJD6F3HW03R
    Num SW: 3058D166
    this version is that you write a different version !!!! Fiat Doblo 1.3 JTDM 2007 ECu MJD 6F3.D1/HW03R/3058-D154
    taras_rx7's Avatar
    Try this and report.Pass in pm.
    Hi all..
    I need remove DPF..
    many thanks!!!
    fgtech2,bdm100,MPPS V12, galletto 1260,fiat ecu scan, vagcom,elm327,mobydic for fiat,MPPS V18
    Carsoftware FAP DPF does not work!
    agreed...
    thanks...
    Jan 2012
    and what could happen after work this program?
    furnata's Avatar
    Bulgaria
    work but get error after some km
    Im here to help and to be helped
    I have fiat doblo1.3mjtd 2009.For mi works perfect Carsoftware,about 3 ans .i have no problem with dpf,all is off.
    I have 72000km with dpf off and no problem,this is good for fiat_opel multyjet.
    i sinc it is ok,but you must elimine fisics dpf.
    you can clik thanks
