Results 1 to 12 of 12
Hybrid View
    Jun 2013
    Default Faulty skybox f3
    Hi everyone just thought id give the heads up on a ebay seller who has screwed me over basically. Bought 5xf3's of him in a few months for myself and a few friends in work. Every box was fine until the last one I purchased for a friend started playing up. It keeps rebooting at random times...sometimes 5 mins sometimes 30 mins. So I sent the box off to the seller with invoice and an explanation to what was happening. ..a few days later I received the box back saying everything was fine and fixed. They said they reflashed it...I checked the firmware and it has the same firmware on it from when I received it originally. I understand that the firmware could be corrupt but I never istalled a program list. Any help would be appreciated guys
    Here is the seller...avoid like the plague
    Sent from my GT-I9305 using Tapatalk
    Jan 2009
    Does it work now? If so what's the problem. If its been fixed, he has done nothing wtomg
    hi mate' i have had a few of these off him and only 1 of them is now faulty' mine own . and that was after the bloody warranty ran out so he says 6 months u get and he also said if u put your own firmware onto them then that also buggers the warranty which i fink is full of crap he is a decent seller but you dont know if you are getting a real openbox/skybox etc' personally i fink they all clones' i got a openbox s11 from him which was my 1st box and it was called odehbox lmao' sounds like a firmware problem/fault with box. best of luck bud
    deano
  4. The Following User Says Thank You to dj1978 For This Useful Post:
    MonsterSquad (6th December, 2013)
    Jun 2013
    No it doesn't work & he has not replied to any of my messages since I received the box back. Any idea's on how to fix this problem?
    Oct 2008
    Just reflash it using software from here
  7. The Following User Says Thank You to sexysam For This Useful Post:
  8. #6
    Jun 2013
    Can someone send me a link for the exact cable I need to buy? There are so many different types on ebay. Thanks
  9. #7
    digicon's Avatar
    Quote Originally Posted by MonsterSquad View Post
    If you have an RS232 port on your computer then this will be fine: RS232 Serial Null Modem Cable DB9 Female to DB9F RS 232 Ideal for Box Flashing | eBay
  10. The Following User Says Thank You to digicon For This Useful Post:
  11. #8
    Jun 2013
    Just checked my laptop and I don't think its the right connection. ...doesn't look the same
  12. #9
    digicon's Avatar
    Thats correct its not the right port what you have there is a DVI-D port for displaying HD onto other devices.
  13. #10
    digicon's Avatar
    after a quick search around it looks like you could get a usb to serial comport cable that will work: http://www.digital-kaos.co.uk/forums...0/#post2028946 that link is to a members post called DW190 thanks to him
    Ebay Link to cables you will need: http://www.ebay.co.uk/itm/USB-to-Ser...p2047675.l2557
    http://www.ebay.co.uk/itm/Starview-K...item45edbedb5c
  14. The Following User Says Thank You to digicon For This Useful Post:
  15. #11
    May 2013
    Why don't you flash the box via usb ? If your box is still booting up and from what you said it sounds like it is then download the latest firmware from skybox.cc
    copy it to your memory stick and Install it.
  16. #12
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    Had a lot of boxes off this seller myself and never had any problems, flashed them with plenty of different f/w and channel list, that's not to say there may be the odd dodgey box though .. i've been into their office and they seem a decent bunch of lads.
    I can tell you they are no longerselling these boxes on ebay as they are moving office and should be back in a fornight?? (that was the reply i got when i phoned up the other day).
    Just have a try leaving the box on with the sat cables unplugged see if it reboots, obviously would need to leave it somewhere to catch your eye if it was to reboot..
    The f/w that came with the box 1st time and the f/w they sent it back to with may well be the same as they flash the box with the channel list and favs named as like sattv5 or aj's channel list.
    The only problem any of my mates have had with one of his boxes came when he decided to move his front room around and plugged both of his sat cable feeds into his box, this caused it to reboot every 20 - 30 mins, so maybe check you only have one feed to the box.
    The easiest way to flash the box is as sattv5 says above, use the usb plugged into the box, just back your important bits up to usb 1st (just incase ) once thats done put a decent channel list on it like the sattv5 list which is regularly updated.
    Good luck and hope you get it sorted.
    If it isn't broke, don't try fixin it..!!!
  17. The Following User Says Thank You to darcu5 For This Useful Post:
    MonsterSquad (7th December, 2013)
