Results 1 to 10 of 10
    Oct 2010
    ireland
    Default transit dash problem
    those any one know can ford transit with 04-06 reg dash clocks be repaired I have often come across these dah clock giving problems thanks
    milesbetteroff's Avatar
    Nov 2009
    Sunny Scotland
    Hi mate these are a very easy repair and if you had searched the forum I have posted this before but just for you here we go , open the cluster and look at both sides of the circuit board very carefully you will notice black spots on it use a fiber pencil and clean them off be careful not to miss any and that's it job done dash will now work perfectly hope you understand this as it is really simple to fix good luck
    Milesbetteroff here to help
  3. The Following User Says Thank You to milesbetteroff For This Useful Post:
    ollync (23rd January, 2017)
    Oct 2010
    ireland
    cheers thanks I have noticed these on several transit dashs before thanks for your help
    Meat-Head's Avatar
    Quote Originally Posted by milesbetteroff View Post
    Same with Focus. Those with more than 300 posts are entitld to get some fairly fine sandpaper and give the board a scrub.
    Anybody with more than 600 posts is then entitles to scrub with sandpaper and simply ram dash back in, any less posts they have to spray board with laquer
  6. #5
    Oct 2010
    Have a 2005 transit and when I start van mileage disappears and all I get along display is ------- ,I've tried 2other speedos and they still have the same problem , this obviously not the dash . Have any of ye guys seen this problem before
  7. #6
    Meat-Head's Avatar
    Yes but not on a transfestite
  8. #7
    Dec 2009
    Had it on fiesta is ecu problem
  9. #8
    Oct 2010
    I think it's Ecu problem
  10. #9
    Meat-Head's Avatar
    Read ecu faults. Speed sensor
  11. #10
    ION CRISTI's Avatar
    Jun 2010
    ROMANIA
    I also found the plug seams to clock, bad solder.
