Results 1 to 3 of 3
    Jan 2013
    Default VU+ solo2 out of range
    Hi. My VU+solo2 box seems to have stopped working with the HD lead.It only shows out of range on all resolution settings. It was going perfect up to yesterday.
    When it was switched on,the screen showed green and then light red for a short time and since then it only displays out of range.It is going ok if I use a scart lead.(HD lead is working ok)
    I am using the latest OpenVix image which I reloaded last night.
    Any help would be much appreciated. Thank you.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Have you checked your av settings haven't changed. setup/system/av settings. Try box on another tv to rule out faulty hdmi. Try another image
