I'll keep it in mind, thank you. I switched from 223 to 247 and it seems to be working great so far. Time will tell...
i think its the game itself as others are having similar problems. try disconnecting your wii from the internet or, at the point where the game freezes try playing with one non swap force skylander. this could be a problem activision needs to sort out.
you could also try unfolding the usb cable completely and placing the portal away from the wii. or lastly try freeing up about 1500 blocks on the wii
Men of Harlech onto glory
This shall ever be your story
Keep these fighting words before ye
Cambria will not yield
Thanks Keithuk: you procedure worked a treat !
Welcome to DK ftual.
I prefer you click the Thanks button as that is logged.
Keith
2010 Golf GTD (170)
Throwaway8430 (7th February, 2021)
Hi folks,
I have a similar problem where the Skylanders swap force portal is not recognized .
I followed Kethuk instructions but the portal still shown as disconneced.
Please help !!!
following is my syscheck:
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 77522611
Boot2 v3
Found 155 titles.
Found 52 IOS on this console. 2 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v5
MIOS v10
Report generated on 2014/02/28.
Welcome to DK rshemtov.
I don't see anything wrong with that sysCheck only PriiLoader 0.7 is missing, add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
Keith
2010 Golf GTD (170)
Priiloader 0.7 installed. problem still exists. Syscheck log:
Region: PAL
Priiloader installed
Hollywood v0x11
Boot2 v3
Found 157 titles.
BC v5
MIOS v10
Report generated on 2014/03/02.
Thanks for your support
Have tried to follow the above mentioned steps but the portal is still still coming up as not detected.
Using USBLoader GX and have the actual portal.
Syscheck is as follows:
sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano ...runs on IOS58 (rev 6176). Region: PAL System Menu 4.2E (v482) Priiloader installed Drive date: 2008.07.14 Homebrew Channel 1.1.0 running on IOS61 HomebrewFilter ist nicht installiert Hollywood v0x21 Console ID: 128496313 Boot2 v4 Found 114 titles. Found 55 IOS on this console. 5 of them are stub. IOS3 (rev 65280): Stub IOS4 (rev 65280): Stub IOS9 (rev 1034): No Patches IOS10 (rev 768): Stub IOS11 (rev 16174): Trucha Bug NAND Access IOS12 (rev 526): No Patches IOS13 (rev 1032): No Patches IOS14 (rev 1032): No Patches IOS15 (rev 1032): No Patches IOS16 (rev 512): Stub IOS17 (rev 1032): No Patches IOS20 (rev 16174): Trucha Bug NAND Access IOS21 (rev 1039): No Patches IOS22 (rev 1294): No Patches IOS28 (rev 1807): No Patches IOS30 (rev 16174): Trucha Bug NAND Access IOS31 (rev 3608): No Patches IOS33 (rev 3608): No Patches IOS34 (rev 3608): No Patches IOS35 (rev 3608): No Patches IOS36 (rev 3608): No Patches IOS37 (rev 5663): No Patches IOS38 (rev 4124): No Patches IOS40 (rev 16174): Trucha Bug NAND Access IOS41 (rev 3607): No Patches IOS43 (rev 3607): No Patches IOS45 (rev 3607): No Patches IOS46 (rev 3607): No Patches IOS48 (rev 4124): No Patches IOS50 (rev 16174): Trucha Bug NAND Access IOS51 (rev 4864): Stub IOS52 (rev 16174): Trucha Bug NAND Access IOS53 (rev 5663): No Patches IOS55 (rev 5663): No Patches IOS56 (rev 5662): No Patches IOS57 (rev 5919): No Patches IOS58 (rev 6176): USB 2.0 IOS60 (rev 16174): Trucha Bug NAND Access IOS61 (rev 5662): No Patches IOS62 (rev 6430): No Patches IOS70 (rev 16174): Trucha Bug NAND Access IOS80 (rev 16174): Trucha Bug NAND Access IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0 IOS222[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access IOS223[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0 IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0 IOS254 (rev 65281): BootMii BC v6 MIOS v10 Report generated on 2014/06/22.
Any ideas on where i'm going wrong would be great!
He Keithuk,
I followed this guide exactly, or at least I thought I did. Here is my sysCheck, do you see anything out of sorts? I'm still getting the error that the portal is disconnected.
Region: NTSC-U
System Menu 4.3U (v513)
Drive date: 2006.05.26
Homebrew Channel 1.1.2 running on IOS58
Hollywood v0x11
Console ID: 34783004
Boot2 v4
Found 121 titles.
Found 55 IOS on this console. 4 of them are stub.
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS90 (rev 54321): Trucha Bug
IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS254 (rev 65280): Stub
BC v6
MIOS v10
Report generated on 2015/01/06.
Cool, this advice still works in 2021. Some pointers for other latecomers. Follow Keithuks advice closely, it's easy to overlook crucial steps. For me, I thought Modmii would copy the relevant files to the SD card, but you have to do it manually. The links don't work anymore and MMM and the IOS236 Installer are not included.
d2x v8 Final wad pack: http://www.mediafire.com/file/x4mf58...final.rar/file
Multi Mod Manager: https://gbatemp.net/download/multi-m....13015/history
ModMii: above link still good.
IOS236 Installer: https://sites.google.com/site/comple...attredirects=0
I finally got Skylanders Swap Force working, on 4.3E, after installing the Final Wad pack. I run the game with USB Loader GX on cIOS 247 or 248. With cIOS 222 or 223 the portal lights up but the screen stays black.
Good luck!
