Results 1 to 12 of 12
    Jan 2009
    Default DM500s Bouquet update
    Has anyone got the latest channel list / bouquets for the dm500s? Anyone have a quick guide on hiow to update its been about 24 months since i last did it.
    Also ive looked in the downloads section and i'm struggling to find dreamboxedit, i'm guessing thats the program still required?
    EDIT: By the way i'm running Commando 14 I think.
    Kevin
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by KevinM2k View Post
    Kevin
    go look in the 500 image section for the newer 14.7 img
    Jan 2009
    Quote Originally Posted by psats View Post
    Alright m8, ive just tried this, so flashed commmando 14.7 and now i have no screen at all.
    Dreamup wont connect via box anymore either, even with serial cable i get just the now turn on box message but nothing happens when I do... any help???
    Mar 2012
    Did you manage to sucesfully flash the Commando 14.7 image to the box?
    You should have got a "flash sucefull" message on Dreamup.
    When flashing the box you use a Null Modem cable and not a serial cable.
    Jan 2009
    Unfortunately no I tried the telnet way and although it seems to go ok when restarting nothing came up I have a serial to usb but just had to order a null modem cable and I'll have to give it another go with that using dream up but cable won't be here for a week
    Sent from my Nexus 4 using Tapatalk
    Sep 2008
    why did you not use the onboard update option in the commando menu..??
    most people who get bad flash after useing telnet usualy reboot box
    after seeing the finnished in telnet window instead of waiting for the box to reset itself.
    Jan 2009
    Aha that's exactly what I did.oops. the commando web interface was German the Google translate didn't help never mind null model cable on way
    Jan 2009
    OK i've now got commando 14.7 installed successfully...
    How do you get the CCCam working?? Googled it quite a bit but found nothing so far, can anyone help?
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Better carry on using Google mate
    Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc.
    Andy.
    Sep 2008
    you need to manualy install then enable it via the menu
    there is plenty of info if you look through some of the other commando threads posted in the 500img section.
    Jan 2009
    Alright, if anyone wants to help via private msg let me know! other than that i'll be googling around.
    Thanks!
    Kev
    Old Git PaphosAL's Avatar
    Mar 2008
    Might help if you go BLUE > TuxCom > and read the 'Hints and Tips helpfile on your telly?
    Particularly the 'Softcam' section! Two minutes reading often saves HOURS of head-scratching and Googling, LOL!
    Cheers- AL
