Page 36 of 41 FirstFirst ... 263132333435363738394041 LastLast
Results 526 to 540 of 601
  1. #526
    FINLY I GOT MAGIC.RAR
    BUT NOT WORK 4 ME
  2. #527
    Originally Posted by Devilfish
    Follow these steps:
    Do a factory reset.
    Do an automatic transponder scan using the settings for your area.
    Go to sky sports one and reboot the box.
    Go to Menu > Setup > Communication Setup and set the ip address.
    Connect to the dreambox with your ftp program.
    Download the files from this link...
    Code: Check this link
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Copy the files in the keys folder to /var/keys.
    Copy all the .bin files to /var/scce.
    Reboot the box using the 'reboot now' option in the shutdown menu.
    Hopefully, all going well, when the box reboots it will show sky sports 1. It might take a minute or two to come on but leave it there and see.
    thanks........
  3. #528
    Nov 2008
    Default Recording...
    After a nightmare time unable to record anything by upgrading to a neutrino image - I had to 'downgrade' to Pli Jade and everything is fine now.
    Can anyone tell me what this is like recording to NAS?
  4. #529
    Really feel I need to vent my frustration here.
    This is really turning out to be an extremely freaking frustrating episode trying to get dm500c to work.
    Trying to follow the threads and history, do and donts was difficult enough.
    I finally plug up the courage to try to flash using the router mode. Followed all the steps but the box just crashed my network everytime when it reboots. so i figured maybe i did something wrong, so i opted to follow the advice of the safest method.
    Using "dreamup" and the null modem cable. So, I go out to buy a null modem cable. I bring it back home and find out that the female to female cable does not fit my "db9" port which is also female.
    So back i go to the shops looking for female to male convertor. Finally, found a shop that has the convertor but I had to wait an hour for them to get it delivered from another outlet.
    Happy , I figured the it will be worth my effort. Brought it home and tried to plug the "converted male" cable only to find out that it was a vga port on my computer I was trying to force the db9 pins into. Silly old me I thought, but where the hell is the freaking serial port on the comp??? there is none!! none of my three laptops and 1 desktop has it !! In this forum seems like everyone assumes there is one and nobody is warned before going out to buy a null modem even though It does tell to differentiate from rs232 serial cable
    so nevermind i tell myself, since i am already so deep into it, why not I will buy myself a usb to serial cable. Found one and came back home to challenge my nemesis but again I cannot another wasted trip and money. Brought the box to the office and yeah found a old desktop with a db9 port. Plug it in and it allows to connect to com2. but the message in dreamup shows "connection prepared now switch on the dreambox"
    It just stays this way - nothing on the log which i read at least ppl have a message "dm500 found" or s/t. Mine just stays like this without any activity. now copying of files no nothing.
    What a bummer !!!! I wonder if anybody else has gone through the same frustration that i have been through
    Not as easy as it appears
    Ronald
  5. #530
    hi ronald :
    when you get the message connection prepared now switch on the dreambox, you basically need to unplug and replug in the power adapter and viola! it will werk!
    hope it helps
    cheers
  6. #531
    hi devilfish :
    can i ask how the internet image updates work? i currently got 3 dm500C boxes at home and another 2 at my dad's place so it can sometimes be a bitch to manually update each dreambox when my provider changes keys etc.
    how do i serve my latest image up to each individual box? hope its not a noob question
    cheers
  7. #532
    hi devilfish :
    How do i update the DM500C ?
    Which file to upload
    thanks you
    trdwish
  8. #533
    Default Basic Setting
    just bought 1 set of DM500C,
    everytime i on the decoder, i need to adjust the volume setting and the default channel. can anyone guide me for the volume setting and the last channel view.
    Thanks and regards.
    guanner
  9. #534
    Nov 2008
    Paddington
    Default image problem
    Hi all just flashed this image on my dm5oo and have got nothing but no signal cannot even ftp to the box to change image. Anyone got any ideas wot to do thanx
  10. #535
    Newbie nightling's Avatar
    Quote Originally Posted by ronaldlye View Post
    Ronald
    Maybe you should have read the guides in depth. I have made a post to highlight the null modem cables and even a picture of the pins on it. Post #475.
    http://www.digital-kaos.co.uk/forums...3/index32.html
    VGA cable is 15-pins. You said you got a serial cable, have you made sure that it is null modem cable? It is different due to internal wiring. There are highlights in the stickies that not all computer has RS232 port, especially laptop. So if you have been through stickies, you would have save yourself wasted trip.
    http://www.digital-kaos.co.uk/forums/f34/shortcuts-relevant-set-up-guides-dm500c-149292/
    You probably switch on the dreambox before you click connect. The program does not work this way. You will have to leave your dreambox off. After you click connect, and it says connection prepared, then you on the box. So either your cable is a straight cable or you have on the box before connect. Just try it.
  11. #536
    Quote Originally Posted by stualdo View Post
    I think your box is dead. Since you can't even FTP which is what happen to me after a bad flash from telnet, you will probably need to get a null modem cable and flash via dreamup.
  12. #537
    DK Veteran standarren's Avatar
    Jun 2008
    BIRMINGHAM
    first impressions are superb
    having moved over from the dbox scene i'm just getting into the dream box just had it delivered today
    the only problem i have is uploading a good bouquets list
    i'm familer with the linux system but it seems more complex than the dbox could someone point me in the ight direction
  13. #538
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by standarren View Post
    After you scan for channs. it doesn't take that long to create
    your own bouquets. You can have them exactly as you want them
    If you use someone elses chann.xml it usually won't be to your
    liking. Back up your bouquets on PC & you will always have them.
  14. #539
    Oct 2010
    Default dm500
    hi will this get hound the problem of nagra 3
  15. #540
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by badger23 View Post
    No, you would need to find a cable-server for card/share, or look
    at buying Kryptvu A780 or similiar LAN box which have servers
    set up for card/share.
    There are plenty of servers for Dream 500s on sattelite
