Results 1 to 3 of 3
    Default Alfa 166 Need code
    Hello, can anybody help me to decode this navi??
    i dont have flash programmer, so i hope so that someone can decode it from serial
    Becker be2580
    s/n: y5040134
    and
    siemens
    swk78206
    s/n: AR2060027799/01
    thnx in advance...
    guys???
    i have readed 29f800 with normal pinout.
    And eprom from becker module 24lc04
    i have put the known code with Nyo4 (6366), than i write into flash.
    now on dislpay only shows ''Bootsektor 5.25 AR lade loader''..
    does anybody have solution??
    dump ''org'' is flash dump, 'org_00 ' is flash dump changed with nyo and 'becker d is dump from radio module 24lc04'
    thank you...
    i solved the problem...
    thnx for help
