Results 1 to 5 of 5
Thread: Passat 3c ELV
    Default Passat 3c ELV
    Hello! I am going to change the ELV of a vw passat 2006. I have the pin but...i dont know the procedure to adaptation. Someone knows if it posible with vcds .
    thanks in advance
    Dec 2010
    Ro
    [Adaption - 10]
    Leave channel at "00"
    [Read]
    [Save]
    [Done, Go Back]
    [Security Access-16]
    Enter the vehicle PIN in a 5 digit format.
    [Do it!]
    [Adaption - 10]
    Read Channel 051.
    The Stored Value will be 32000. Enter the PIN in the New Value box.
    [Test]
    Wait | N/A | N/A | N/A Will be displayed. Wait until the ID numbers
    are transferred into the first 2 boxes. If you aren't sure, be patient
    and wait at least 30 seconds!
    [Save] (Note: if Save is not available and the data in the last step has
    transferred continue by exiting)
    [Done, Go Back]
    author......ROSS TECH
  3. The Following 2 Users Say Thank You to emanuel2010 For This Useful Post:
    GaizkaV8 (15th December, 2013), yugo45 (4th February, 2014)
    I imagine that these i have to do in 25.immobilicer?
    Ok. perfect emanuel2010. these was the procedure 100%
    thankss
    dantetimoc's Avatar
    hi , i need some help!
    i have respected above procedure but something is vent wrong... the ID number was not transfered in first 2 boxes, nothing i have waiting about 10 minutes!
    now when i try again to "test" pin on chanell 51 i get "wait " for short time and the "not ok"... and i have this error in immo (25) : 02822 Electronic Steering Column Lock Incorrectly Installed
    Autotuner- Kess 3, genuine master tools.
