Results 1 to 11 of 11
Thread: MED 9.1 clone
    Apr 2010
    Default MED 9.1 clone
    Im trying to do some research how to virginise or clone VAG MED9.1 I have found some threads where people were making immo off for this ECU. I read another thread where was a discussion about MED17.1 ECU being Tricore ECU and so far is no option to virginise or clone this type of ECU.
    Is MED9.1 a tricore ECU ? Can I read full ECU content by BDM and just upload it to another MED9.1 ? Can I modify the content and make it Immo off ?
    If somebody would shine some lights on all these questions that would be great.
    Feb 2013
    MED9 is not tricore, You can clone the ecu just by copying the e2p and flash to a replacement. You can also immo-off it. If you need info on the e2p checksums, feel free to ask.
    Apr 2010
    I cant find any info on how to do immo of on this ECU. Would you point me in the right direction ddillenger84 ?
    Nov 2008
    places
    if you can bdm it and you dont NEED immo off, then just reflash new ecu with the bdm read and it will be a 1:1 clone and work in the car.
    genuine tools owned: too many
    genuine software owned: have lost count
    Apr 2010
    If the MED9.1 is not the Tricore ECU than Yes I can just BDM the Flash and Eeprom and upload it to the new ECU. Can somebody point me in the right direction how to do Immo in MED 9 and ME7 ECU ? What needs to be modified in the Flash or EEprom?
    Feb 2013
    Quote Originally Posted by astrofil View Post
    Noone is going to just give you this information for MED9.
    ME7 however, is attached below. ALSO! Make sure to decrease the values in 1F and 2F by the amount you incremented 12 and 22 in order to update the checksums.
  7. The Following 2 Users Say Thank You to ddillenger84 For This Useful Post:
    astrofil (18th December, 2013), luis12 (24th December, 2013)
  8. #7
    Apr 2010
    Thank You for the info on ME7. I assume I have to read the EEprom memory of ME7 and do the mods right? Can I use MPPS to do the read? I have also Willem Programmer if needed.
  9. #8
    Nov 2008
    places
    gq3x is a much better and still cheap option compared to a basic willem. my lpt willem had problems writing the 95040 chip.
    there are tools to read/write me7 e2p in bootmode though. mpps is not one of them. mpps only r/w flash.
  10. #9
    Jan 2019
    hi all,
    I need to clone a MED 9.1 but I have only the eeprom backup from the old ECU, can I make IMMO OFF on the new ECU or I need to change also VIN code ?
  11. #10
    Jan 2013
    post eeprom dump ill help
  12. #11
    Apr 2024
    Hey could you immo off my med9.1.1 I have eeprom and flash file
