hello ive try all the channel lists on here but none seem to work so is there a working one about
on most ov the hd channels don't work no signal
I will ask the same questions that have been asked many time's maybe a few 1000's time's
Do you have an original box connected at the same time ???
What box do you have
Wired or wireless (connected)
was there a problem with the channels before the update ??
have you changed the firmware ??
Have you checked the cable's are ok........
There's a few to start....the more info you give the easier its is to help without playing a guessing game......and then the thread becomes 5-6 pages
long
Hi I'm having the same sort of problem with my mates F5 boxtried to update with the misc files but its not picking the TP_PROG.dbs at all, I've reset it to factory settings with no luck, tried deleting all the channels but it still cant see the file. I've updated the .abs file easy enough with a 3601HD_Backup.abs but its still the same. I have unzipped and placed the .dbs file on the root of the USB stick using various files from AJ and sattv5s but it doesn't pick up any of them so there is nothing to select. I even tried a couple of different USB sticks. Any ideas?
