Results 1 to 15 of 15
    Default C36 AMG cluster please help increase kms
    I have a customers Mercedes w202 c36 cluster that has a disfigured lcd temperature display, i have tried another lcd display and it did not make any difference, i then tried swapping 93c56 into another cluster with the exact same part number with same software and hardware status, as soon as i swapped the eeprom to the good working cluster the Temp display became disfigured exactly the same as the original cluster. I soldered on the original eeprom back on the good cluster and found it to work normally, which means the customers eeprom software is corrupt.
    The customers cluster has traveled 175,000kms and the donor cluster has traveled 110,000kms. can someone please help me adjust the kms in the good eeprom from 110448kms to 175,903kms, i am happy to pay for your time to help me with this.
    The eeprom with 175,903kms has the markings 93c56 on it
    The eeprom with 110448kms has the markings cs566 on it.
    The part number of both clusters is A2025400111 and the Motometer number is 5220301300
    Thanks Juz
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    here u go my friend PM memb mm w202 175903km 93C56.rar
    Reading is fundamental, asking is easy............................
  3. The Following User Says Thank You to XmoDDeR For This Useful Post:
    juzzac (18th December, 2013)
    Hi Xmodder,
    Thanks for all your help, it now shows exactly 500,000kms instead of 175,000kms do you have any more ideas ?
    Juz
    captain crackers's Avatar
    england
    This is correct. Arthur.
  6. The Following User Says Thank You to captain crackers For This Useful Post:
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by captain crackers View Post
    captain trying to compare both bins for mismatch to tweek calc , did u see which
  8. #6
    england
    xmodder, I just did what juzzac wanted. Arthur.
  9. #7
    XmoDDeR's Avatar
    Mar 2011
    Hahaha
  10. #8
    england
    Juzzac, I have just looked at your 175,903 bad dump. you have read it as 8 bit. It should be read 16 bit. But no problem as you are going to use the other dump which I edited and that is 16 bit. Arthur.
  11. The Following User Says Thank You to captain crackers For This Useful Post:
  12. #9
    Thanks so much Arthur and Xmodder for all your efforts , I will test it in a few hours and let you know
    also thanks for advice re reading 8/16 bit ( I'm still learning )
    Juz
  13. #10
    Thanks Arthur, I now have a working temp display and correct kms, I have just tested on the bench but i am sure it will work fine in the car when it returns next week
    Once again i appreciate all your help !!
  14. #11
    Sep 2015
    how did you read this chip (CS566 chip). Im trying read (with willem) as 93c56 but all memory display the same digits (for example: 7E 7E 7E........).
    Thanks.
  15. #12
    Sep 2015
    Hi again,
    can someboy modify my dump with 145.000KM?
    I wrote the dump from juzzac with 110k and it works perfect in my dash.
    Thanks in advance.
  16. #13
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by chewaca View Post
    Hi again,
    Thanks in advance.
    Try this.
    amg145.000.rar
    Algo its very easy 145.000 -1= 149999 from line 18 to line 00
    from right to left
  17. #14
    145000 km good
  18. The Following User Says Thank You to nikz For This Useful Post:
    chewaca (9th November, 2016)
  19. #15
    Feb 2022
    Sorry to refresh this old thread, but I need help. Could somebody change the 110.448km file from the first post to 82.104km - When I try it, I get only 500.000km in the Display.
    I tried to count backward, but I'm doing something wrong.
    I changed the damaged Display in a C36 odometer and it shows nothing. I load the 110.448km file from the first post in it, and it works, but with wrong km.
    Thanks for your help.
