initial files and your tuner are bad . here try this. let me know if car starts ok
WinOLS (Audi A4 (Version 1) as (All elements) - 396484).rar
Hello everyone here is my concern.
I wanted a d?ffaper Audi A4 2L 140cv 2008 with edc17c14 computer .
My file is prepared by a very serious ga so I have to do the reading and writing with my gear fgtech V53 clone.
Initially I follow the instructions I read in the boot and INTFLASH eeprom ok no worries , I send my trainer who has me reconsider what time after change
in the night.
I then decided to attack the writing on always at night.
The morning I open up my pc there is an email warning me that my trainer
telling me that my file is corrupted on reading and writing do not
TOO LATE I 'd done the day before.
file missing maps
I went up the computer the car will not start and ventillo constantly running and calculo no longer responds to diag ( checksum error I think)
My trainer has struggled all day to build me a new mapping .
I am facing this problem:
First what are the mapping of my preparer will revive me the car?
Secondly how to inject the new mapping with my fgtech deffaiant ?
I also do tests and compare 3 mapping read as a result of the same computer
between 1st and 2nd reading 8 errors
between 1st and 3rd Reading 4556 errors
help me please
I will put at the disposal 3 mapping
file corrupted first reading
File change my trainer first
rebuilt by my trainer file
Hello
1) Your read is corrupt. Your "Trainer" should have seen that!
2) Your file was already tuned before. Your "Trainer" should have seen that!
3) Your DPF off is done wrong. Your "Trainer" should have seen that!
4) Your reconstruct is done wrong. Checksum is wrong. Your "Trainer" should have seen that!
5) Your car could have been tuned over OBD initially. No need to open ecu. Your "Trainer" should have seen that!
Result: Your car can only be fixed with a well prepared file and a tool that writes the file WITHOUT checksum. Like Byteshooter.
AND: Time to find a good tuner! Your "Trainer" must be a clown.
TRAINER FOR CIRCUS :>
You need a tuner
Hello thank you for helping me
Yes mapping was modified by the former owner of the trainer immediately saw and he also told me that I could work with OBD
he noticed the mistake but it was too late because I had already written.
This suggests that the latter may file built to start the car?
How to ensure good writing with fgtech V53 clone?
And finally yes I want a programmer for my money you can file against
Contact me kenza287@hotmail.fr
Ufff that google translation is really hard to understand. Google should improve it
goodnight ominimicu your file is in the computer I check but the car does not start
you have to calculate the checksum?
Thank you for helping me
here i repaired yours using some i found over the internet. but your original is a tuned file not original SHould work perfect now.-write it in boot mode of course!
WinOLS (Audi (Repaired boot flash) as (All elements) - 396484).rar
