Results 1 to 5 of 5
    psico's Avatar
    Default is tprot? 0281014883 1039s27724
    hi friend, i have read and write this ecu and, question is...tprot or not?
    is only edc17 u01 or TPROT8/10
    thanks in advance.
    carmageddon's Avatar
    Italy
    number 1039xxxxxx on alu label in not SW number.
    SW number is always 1037xxxxxx.
    03G906013K_2940_0281014883_1037395434 have tc1766 with TP active
    psico's Avatar
    This is the image of label, this ecu is tprot?
    thanks friend
    Italy
    as you can see i write the same number you have on the label, therefore your ecu have tp active
    Quote Originally Posted by psico View Post
    thanks in advance.
    Normally, edc17u01 can read-write in obd without problem, tprot level is low.
    If ecu have Tprot8/10, you need read pass before read in boot.
    You can read-write this ecu in ob without problema Tprot level is low, very low.
    Br.
  6. The Following User Says Thank You to gezame For This Useful Post:
    psico (19th December, 2013)
