i have the latest upa 1.3 b.14
will upa usb read and write to MC68HC912B32 1L43M.
if so what are the pinouts??
its from a 2002 Volvo S40 30613049 A
DON'T JUST SAYPRESS IT.....
Hi. Here's upa diagram....
BR
geocity (16th May, 2017), joaopereira6 (7th February, 2022), klonone (21st December, 2017), kronos2k3 (3rd July, 2023)
i have a question to the diagram.
On the picture is UUSP with Number start with 1,2,3,4,5,6,7,8,9
i would like which of this number is vdd,vss,reset ...
joe1953 (25th December, 2013)
Lift reset
lift reset,bkgd ,and connect pins like in diagram and work 100%
i try reading it like picture above. i get bad BKGD, .
i try reset lifted, bkgd to board, i try bkgd lift, reset to board, i keep getting BKGD bad on upa
above pinout works for me, don't have to lift any pins, i also use original UPA , if it doesn't work for you then i would say your mcu is dead
lift pin reset and bkgd
Everything will be okay!
