Page 12 of 33 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 482
  1. #166
    Quote Originally Posted by obdmaster View Post
    What do you honestly prefer your A9 or condor ??
    Thanks again
    Paul
    condor seems a bit hacked together software wise and like the redesign of the jaws, but seems solid enough build, and I can't see them dropping updates when they are linking option in VVDI and bmw multi-tool with the cutter
    I personally dont hold much faith in the long term updates in Miracle machines anymore with them dropping the a5 and creating too many different versions, but they have released the new A9 software and added it to instacode.
    So its a hard one, right now if I could only have 1 machine it would have to be the A9, but if I didn't have any machine I think I'd want Silca Futura and condor as a workhorse on common cheap jobs
  2. The Following User Says Thank You to paul_12345 For This Useful Post:
    obdmaster (13th December, 2014)
  3. #167
    Dec 2010
    Nottingham
    or me , i like condor alot , i also like my miracle A6 alot , but if i had to choose just one machine then id stick with my silca viper , this has been a solid workhouse , its been on van for 8 years cut well over 16000 keys and is still as good as new .
    condor is a great machine at price , but will never replace silca despite having its uses.
  4. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    obdmaster (14th December, 2014)
  5. #168
    obdmaster's Avatar
    Never never land
    I have 51cm height from top of my worktop to roof, whats your opinion will condor be useable?? Or not enough space ??
    You need every tool in the book, to do this auto locksmith job.
  6. #169
    you can remove the feet to reduce the height a fraction, you could use it but the viewing angle wont be brilliant, you can easy make out high contrast buttons etc like black and white on key type selection but a lot of buttons are hard to make out at that angle but doable.
    in the worse case you could always get a small camera and lcd or tablet etc to get a better look if you wanted to.
  7. The Following User Says Thank You to paul_12345 For This Useful Post:
  8. #170
    I've just poped the top off and theres 2x 5 pin connectors for the 2x side buttons and 1x connector for the screen which is a standard pc ide cable type so if you really wanted you could get a long ide cable and remove the screen and mount it at the side and have the cable come out where the screen is.
  9. The Following User Says Thank You to paul_12345 For This Useful Post:
  10. #171
    Dec 2011
    Condor will produce three different types and sizes of key NC machines, manually key-cutting machine, and the design and production of new types of fingerprint lock, universal anti-theft car chips. ... Is the research and development company in China.
  11. #172
    Feb 2014
    You can also remove the shield...
  12. The Following User Says Thank You to autoTkey For This Useful Post:
    obdmaster (15th December, 2014)
  13. #173
    florinyes's Avatar
    London Middlesex
    anyone managed to cut Mercs HU64 key fine? is not decoding the entry OK.
    Whatever seems impossible is just not yet important enough.
  14. #174
    Mine is doing the same thing. I have yet to try 'direct cut', I wonder if it would do the shoulder correctly, they still work, in the door at least, so maybe the tip isn't as important?
  15. #175
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by rapidlocksmiths View Post
    you do 8 key/per day ?
  16. #176
    Dec 2010
    Nottingham
    i cut alot of keys for customers , not as many as i used to since cut to code machines have dropped in price as more have their own machines now , and i used to cut alot of overlifters but again since the lishi 2in1 these have all but dried up now , but these customers over the years paid for my machines and the ones that remain provide me with a good side income
  17. #177
    kevfield's Avatar
    uk
    florinyes Hi pal decode key manualy with Vernier Caliper and see if bitting you get is different than condor decodes if it is then cut to your manual decode......
    Thanks kev
  18. #178
    some tibbe pictures random bitting (241321) took around 7 mins 15 seconds (angle is slightly to one side due to me rushing and not putting it in 100% flat)
  19. #179
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Ain't a pretty key paul
    as long as it works
  20. #180
    Quote Originally Posted by whiskeyman View Post
    as long as it works
    to be fair it looks better in person, but they do need to change it so that it cuts in 2 passes to get the correct width rather than having one 1.5mm cut to remove the silly lips on each cut
    this wouldn't take much extra time at all and look far better
