Page 17 of 33 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 482
  1. #241
    Apr 2015
    Quote Originally Posted by paul_12345 View Post
    you think anyone is going to buy another clamp when you haven't sorted out the problems with the ford clamp??
    i have tested ford clamp is ok,and could you sent me the photo/take a video about your problem?
  2. #242
    Quote Originally Posted by Samic View Post
    I sent all details already, cut number 4 cuts to deep mainly on one side, a few people here have said the same. It may still work but looks ugly and no self respecting person could give their customer the key like that.
    I think cutting all cuts with the cutter 0.05mm higher up would still work and should solve the problem.
    or maybe just cut number 4 0.05mm higher
    or just the one side that cuts deeper 0.05mm higher.
    Which ever works best.
  3. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    dustin2014 (24th April, 2015), rm23 (30th April, 2015)
  4. #243
    Apr 2015
    i have tested,maybe you haven't put the key in the same direct horizontal line,you can see the condor xc-007 tested cutting photo.
    the upstairs key→the origin key,the downstairs key→condor XC-007 cutting key
    and the cut number 4 is ok,all cuts is ok if you keep the clamp Rotate to a fixed position.
  5. #244
    Where is the option to cut the tibbie keys? I have version 2.2.8 and can't see it under ford/jag I have the x3 clamp also.
  6. #245
    Feb 2014
    Just select the car make and the corresponding key blade signature (for Ford tibbe) and it will go in to tibbe mode.
  7. #246
    No option on mine for that I select ford then it says input key code and under that it says series hint
  8. #247
    May 2008
    can you post a larger picture.
  9. #248
    Jun 2014
    Try updating the software.
    Update 2.2.9 includes: Modify X3 FO21
    There's been a few updates since 2.2.8:
    v2.3.0 Beta 7 (2014-11-12)
    * Fix bug of key learn
    v2.3.0 Beta 6 (2014-11-11)
    * Modify HU56 shoulder
    * Fix HU64,HU101 shoulder error
    v2.3.0 Beta 5 (2014-11-10)
    * Modify HU71 tip
    * Modify TOY43 bit flat to 80
    (down from 100)
    * Modify TOY43 tip
    * Modify HU101 shoulder
    * Modify HU64 shoulder
    * Modify HU100 slot width to
    280(up from 250)
    * Modify TOY40 tip
    * Modify TOY48 tip
    * Add comment for HU49 246/
    256
    * Z-axis cutting times adjust is
    back
    * Increase history record counts
    * Laser keys shoulder are more
    rounded
    * Fix a bug of params or picture
    may be lost when turn on the
    machine
    * You can choose which version
    to update with new update
    tool(v1.4.3)
    v2.2.9 (2014-07-18)
    + Add select keys by car model
    + Add key abrasion correct in
    key learn
    * Increase history records length
    and total count
    * Modify HU66 tip and shoulder
    * Height detect is now using cutter
    * Modify HON66 tip
    * Modify HU83 EXT shoulder
    * Modify TOY43
    * Modify X3 FO21
    + Add RENAULT key
    + Add GREAT WALL key
    * Update speed increase
  10. #249
    please show a bigger picture.
    also a few people have said he same issue as me, it is in the correct position - if you rotate the other way it would cut the other side too much also.
    The only difference could be the cutter - I do not see anywhere where you sell the cutter made for the condor - please post a decent picture of the cutter and where to buy the same cutter as you
  11. #250
    Can someone please upload the update tool and drivers I have downloaded the updated tool in post 53 when I open it it say this application has failed to start because FTD2XX.dll was not found reinstalling the application may fix this problem. Also when I connect to the computer it wants drivers for the key machine.
    Galee
  12. #251
    Jun 2014
    I'll upload them in a few minutes
  13. The Following User Says Thank You to dustin2014 For This Useful Post:
    Galee (28th April, 2015)
  14. #252
    Jun 2014
  15. The Following User Says Thank You to dustin2014 For This Useful Post:
  16. #253
    Jun 2014
    Do you mean the proper 1.5mm & 2.5 mm cutters?
  17. #254
    Quote Originally Posted by dustin2014 View Post
    you can not use 1.5mm as they haven't programmed it to do 2 passes to cut the correct 2.2mm width.
    2.5 is just too big even if it works I dont want some ugly key.
    I think they said it works ok with 2mm but I want a picture of the key cut with the condor and details of the cutter that cut it so I can test it.
  18. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    dustin2014 (29th April, 2015), insomnia2009 (28th April, 2015)
  19. #255
    Dustin2014 thanks just what was needed most appreciated.
  20. The Following User Says Thank You to Galee For This Useful Post:
    dustin2014 (28th April, 2015)
