Page 18 of 33 FirstFirst ... 8131415161718192021222328 ... LastLast
Results 256 to 270 of 482
  1. #256
    Jun 2014
    Gotcha mate.
  2. #257
    Apr 2015
    Quote Originally Posted by Galee View Post
    Where is the option to cut the tibbie keys? I have version 2.2.8 and can't see it under ford/jag I have the x3 clamp also.
    the latest version is V1.4.3 include(2.2.9&2.3.0beta7),you can update to the 2.3.0beta7.
  3. #258
    Apr 2015
    Quote Originally Posted by paul_12345 View Post
    please show a bigger picture.
    also a few people have said he same issue as me, it is in the correct position - if you rotate the other way it would cut the other side too much also.
    The only difference could be the cutter - I do not see anywhere where you sell the cutter made for the condor - please post a decent picture of the cutter and where to buy the same cutter as you
    2.0-2.5mm cutter is ok of this key,1.5mm connot for this key
    the 2.1mm cutter is best ,but we always use the 2.0mm cutter.
    this is the photo
  4. #259
    Apr 2015
  5. #260
    melbourne, australia
    Can someone please upload the update tool and drivers I have downloaded the updated tool in post 53 when I open it it say this application has failed to start because FTD2XX.dll was not found reinstalling the application may fix this problem. Also when I connect to the computer it wants drivers for the key machine.
    Galee
    Im not trying to be smart, but do you realize the Condor doesnt decode the Tibbe keys? you just enter the bittings and it cuts it?
  6. #261
    Yes I understand that thanks I did not have the option to cut tibbie keys on my firmware version now I upgraded the option is there and all is good.
    Cheers
  7. #262
    Can you do a picture from the side so we can see the cuts properly? Thanks
  8. #263
    Apr 2015
    this is the condor XC-007 cutting key
  9. #264
    Quote Originally Posted by Samic View Post
    exactly its cuts too deep. it should not be cutting into the part I've highlighted
    if you set the cut height 0.05mm higher it will probably not cut into it
    whether you can cut all cuts 0.05mm higher
    or just number 4 cuts 0.05mm higher
    or just cuts on the right hand side as the cuts on the right side cut slightly deeper due to the way the machine moves (putting pressure very slightly rotating the key into the cut as it moves whereas the left sides direction of cut rotates the key so it cuts less) if that makes sense.
    probably the most simple and effective solution would be to enable the height adjustment setting (which is ignored for x3 clamp) or better still have 2 height adjustments for left cuts and right cuts, allowing the user to tweak the settings to best suite them.
  10. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    cqae (30th April, 2015), rm23 (30th April, 2015)
  11. #265
    Apr 2015
    probably the most simple and effective solution would be to enable the height adjustment setting (which is ignored for x3 clamp) or better still have 2 height adjustments for left cuts and right cuts, allowing the user to tweak the settings to best suite them.[/QUOTE]
    thanks for your good idea,we will enter “cutting depth”for FO21 in the next version,then send to user.
  12. The Following User Says Thank You to Samic For This Useful Post:
    paul_12345 (30th April, 2015)
  13. #266
    please listen to Paul!.......
  14. #267
    Apr 2015
    Quote Originally Posted by cqae View Post
    yeah,we will add the height adjustment setting for X3 clamp in a short time first.
  15. #268
    Feb 2014
    What happened to update 2.3.1 ? I saw it yesterday in the update tool but now it's gone....
    There was no info what it changes so I decided not to do it.
  16. #269
    Aug 2010
    mr Samic
    this issue is not rective until now ,pls tell us when Hyundai ACCENT 2011+ will be add????
    Quote Originally Posted by siyadk View Post
    Condor engineers and dk contributors ...pls inform the company that it cannot cut these two types of keys
    http://store.hklock.com/hh11341008.html
    http://store.hklock.com/hh11048001.html
  17. #270
    Apr 2015
    Quote Originally Posted by autoTkey View Post
    2.3.1 is our test version(only upload to the server yesterday),still unrelease.you can still choose 2.3.0beta7,
    after all is ok we will update the new software.
  18. The Following User Says Thank You to Samic For This Useful Post:
    Automat (30th April, 2015)
