Page 7 of 33 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 482
  1. #91
    Dec 2010
    Nottingham
    the key stop could be longer which would help on some keys where position is crucial , its the same with HU58 . ive made a longer stop which allows me more accuracy with this positioning on the laser clamp , so i can place at exactly position 1 or 2.
    some keys dont matter as the sensor measures tip position , on some it doesnt measure tip position so correct positioning is crucial.
    make yourself a longer stop piece and it will work fine.
  2. #92
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
  3. #93
    Rtronics's Avatar
    Australia
    There is a new update. i updated 2 days ago. new menu. dont need to select blade, but you can select car, you can do it either way. also re done w203 key now after update, no problems. contact your supplier for update. enjoy.
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
  4. #94
    armpower's Avatar
    Jun 2009
    Italy
    Hallo mate
    In the last 10 days the Condor support torught Skype is down.
    So i can't upgrade to version 2.29 because i need the latest update tool software.The old one not work.
    Can you post here the update tool software?
    Another question.Have you experienced some problem cutting GT15 keys.
    Sometimes the cut is misalligned.When the Condor try to cut the 2th side of the key , during the translation from one side to other, the cutter cut the tip of the key.
    After the cutting operation the final key is without the tip (truncate tip).
    I hope you have understand my poor english.
    Many thanks
  5. #95
    melbourne, australia
    hey r tronics, I'm in aus too, as you already know, where did you get your condor from?
  6. #96
    aassfour's Avatar
    May 2013
    kensington
    anyone have a link to download the software for the condor ?
    mine arrived without any CD
    The only place success comes before work is in the dictionary.
  7. #97
    Dec 2011
    hi,armpower,you can give me your skype,i can help you.
    2.29 is good!
  8. The Following User Says Thank You to diagprog7 For This Useful Post:
    armpower (31st July, 2014)
  9. #98
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    Many thanks for your help.
    I've send to you a PM.
    Cheers
  10. #99
    CONDOR Automatic Key Cutting Machine Online Update Tool V1.4.1(en)
    Zippyshare.com - CONDOR Automatic Key Cutting Machine Online Update Tool V1.4.1(en).rar
  11. The Following User Says Thank You to MrSporty For This Useful Post:
    aassfour (6th August, 2014)
  12. #100
    Just a quick addition. The update runs slightly different to previous ones, the Condor will reboot a couple of times (once with no icons) then the last part seems to contact their update server quite a few times before completing. Took a total of 15 mins.
  13. #101
    Dec 2011
    Yes, early upgrade to 1 hours, the new update, faster, the expected time is 10-20 minutes.
  14. #102
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    I've tried the upgrade but the upgrade stop after connecting to server.
    Now my Condor display internal error 1.Some parts of software not work.
    I've tried the internal erro fix in the upgrade tool but not work.
    Have you got and idea?
    It's a bit of pain for me because i can't use the Condor.
  15. #103
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    I've retried today.Sorted!!
    The update goes to the end without problem.
    Anyone have experienced some problem cutting GT15 Keys?
  16. #104
    Rtronics's Avatar
    Australia
    Anyone cut a Lexus key successfully ? Put in the bitting and its wrong. Nothing like the picture.
    Sent from my iPhone using Forum Runner
  17. #105
    Mar 2014
    West Sussex UK
    Just cut a toy48 to check. depths and spaces are correct but look a little different to the image on the screen. I tapped in some random bittings to test.
    used axis A-13535
    axis B-13531
    But it actually cut
    axis A-13335
    axis B-13531
    so there does appear to be some sort of problem on this one
