Page 8 of 33 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 482
  1. #106
    just got my new toy.. f**k me this things a lot bigger in person!
    NE73 decoded and cut looks a bit odd compared to miracle cut key and original but works ok
  2. #107
    Rtronics's Avatar
    Australia
    Quote Originally Posted by Cromwe11 View Post
    Just cut a toy48 to check. depths and spaces are correct but look a little different to the image on the screen. I tapped in some random bittings to test.
    used axis A-13535
    axis B-13531
    But it actually cut
    axis A-13335
    axis B-13531
    so there does appear to be some sort of problem on this one
    Yeah I did the same. Doesn't cut what you put in. I'm guessing that if key code is not in database it won't cut properly. It should cut whatever bitting you put in manually.
    Sent from my iPhone using Forum Runner
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
  3. #108
    Dec 2010
    Nottingham
    you have to be spot on with shoulder placement on ne72 and ne73 or it miscuts , and you should use the 1mm cutter for best results on ne73
  4. #109
    Quote Originally Posted by rapidlocksmiths View Post
    yh, I found that out the first cut why they just didn't do end stops I dont know!
    I use 1.5mm all the time anyway
  5. #110
    Feb 2014
    I'm just wondering. How helpful is that machine if the client has lost all his keys and there's no key to decode?
    Is taking the lock apart the only "universal" way to get the mechanical key code for cutting the key?
  6. #111
    Dec 2010
    Nottingham
    the machine can
    1) cut to manufacturers key code
    2) copy an existing key
    3) you can enter the key cuts and cut the key
    4) if you only have partial cuts , you can enter the cuts you know and use the built in fill program to find the missing cuts or crate a cutting tree to cut
    so it can do what most other machines can do without the need for instacode as find biting program is built into machine
    so if you dont have a key to copy , and you dont have a key code , then you must either pick and decode with lishi then enter the cuts you want , or pull the lock , strip , read and enter the cuts , just as with every other machine , no machine can create a key without the code , cuts or key to copy , so it is as helpfull as all other key machines , more so if you dont have instacode as it has a fill program built in.
  7. #112
    sorted , clamp was siezed , now up and running so the fun begins.
    after a quick scout through the software , there is no functions for VA6 at all , so no coverage yet of clio 3 , aygo , new ds3 , and no coverage yet of renault card keys either .
    im going to send details to see if these can be added .
    now its up and running its time to play
    My clamp is siezed as rapidlocksmiths described (just received the machine). Anyone else had this issue? How did you resolve it safely?
  8. #113
    Dec 2010
    Nottingham
    no its not , dont fully unscrew the red knob , unscrew a little till loose , then strike downwards on the red knob , the cutter is then released , you strike the red knob every time to release clamp .
  9. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    dmp (10th October, 2014)
  10. #114
    thank you!
    It certainly didn't feel like the right thing to do but worked like a charm
  11. #115
    Dec 2010
    Nottingham
    they sent me a video to explain it , its simple once you know
  12. #116
    Dec 2010
    Nottingham
    if you pm me your email address il send you the instruction pdf ( user manual ) its too big to attach , forum wont allow me to attach it
  13. #117
    likely a stupid question but I've searched and cannot find it (could be tired). Where can you choose the number of passes on the z-axis? I couldn't find it on the machine, in the manual or online (I've seen it in a video somewhere but can't remember where). I found the menu with the speed of cutting and the size of cutter but no more.
    Also, what is the machine password? It is some default?
    Thank you for your help! This machine works great, I cut some vag keys and a TOY48 blade and they are spot on. So far, just getting used to it but seems great
  14. #118
    Feb 2014
    Could you upload it here, for example:
    https://mega.co.nz/
  15. #119
    DK Veteran 54321's Avatar
    Quote Originally Posted by dmp View Post
    password is 123456
  16. The Following User Says Thank You to 54321 For This Useful Post:
  17. #120
    The manual can be downloaded here
  18. The Following User Says Thank You to 54321 For This Useful Post:
    Cromwe11 (10th October, 2014)
