    Apr 2009
    Default Using Nabilosat Pureflash and CF Card?? Help!
    Hi all,
    I'm looking for some help on how to use Nabilosat's Pureflash with Barry Allen as I'm completely confused about how this works....!
    I'm currently running Nabilosat Blackhole v0.9 on my DM7025. I was advised to get a Compact Flash card and run the image, EPG and Picons all from the CF card as this would speed everything up and run everything more smoothly. I've bought a Compact Flash card but I don't really understand what I have to do to get the whole thing working as I cannot find anything on the web that explains this well and in detail.
    Do I have to flash both the Nabilo Pureflash Barryallen and the Blackhole V0.9 to the DM?
    If so, which do I flash first?
    Do I flash with or without the CF card in the box? (have read conflicting info about this)
    If anyone is running this successfully and could tell me the order in which I need to do things that would be great. Thanks!
    V.I.P. Member westkill's Avatar
    May 2008
    flash image pure to the box then follow instrctions for setup it will install barry allen it will look for cf then usb then hdd once it sees your cf card it will add somefiles
    then when you chose to picons from the addons manager pick the ones for cf card and for you epg.data etc
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    Apr 2009
    Cheers Westkill. Is Blackhole V0.9 included on Nabilosat Pure then? I know how to get the Picons/EPG working off of the CF, the part I'm confused with is whether Blackhole V0.9 is included in Pureflash or whther it has to be flashed seperately after Pureflash is installed.....?
    And is there any way of testing if my CF Card is compatible with My DM beforehand? (I have a MyMemory branded one 4GB, 133X)
    Thanks again
    May 2008
    put this one in the flash
    Digital Kaos - Downloads - Nabilosat DM7025 Pure Flash 23FEB09, with Barry Al
    put this one in mb_images
    Digital Kaos - Downloads - Nabilosat Enigma2 Black Hole - DM7025 v0.9
    do you have a hdd installed as well
    if so it should create a folder called mb_images were you ftp nabilosat v0.9 image to and it will extract it to the cf card ready for booting
    if no hdd in should create the mb_images folder on the cf card
    so ftp your image here and it will extract it to the cf card ready for booting
    then when barry allen is up and running presshold blue button to bring up barry allen menu
    May 2008
    Quote Originally Posted by 4tothefloor View Post
    Thanks again
    most of the time it should work the cf its hard to tell on the pure flash image
    hopefully it will see the cf card after giving it a reboot
    when it installs barry allen you dont want it running purely on the hdd if you have one, this means any image extracted will be runnig on hdd and will never sleep
    Apr 2009
    Cheers Westkill, all installed and working fine now (well so far anyway)!
