Nobody ?
Happy New Year !
Nobody ?
Happy New Year !
hello i have done some with cmdflash the connection is automatic because cmd supply a edc/med connector with the tool
warning file bdm content immo data in flash you may look your sam with data from other cars ...
Do You connect here ?
Thanks!
no it's like mercedes you need to remove all from the alu box ....
the connector is on the other side ...
there is risk of break the pcb
why do you want to do it bdm .?
works great over obd ...
Gizbern (6th January, 2014)
Or remove flash and mount one an Ecu already destroyed to read!
BDM pads are on the other side of the PCB. It can be done but I would not risk on a customer ECU.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
i owned a forfour cdi 95 from 2004 to 2009 i did the first read bdm but later optican and cmd release a obd protocol can and kline
so i never more did it bdm after that
i sold the cdi but still have the 05 brabus forfour
if you change vin car no more start ....
