Results 1 to 9 of 9
    Dec 2013
    Default ethernet connection essential?
    Is the Ethernet connection essential to connect to the internet on my skybox? or will it work fine with the wifi dongle??
    Sep 2008
    It all depends on what model Skybox you have
    Dec 2013
    I have the f5s model, im unable to use Ethernet as im currently using my neighbours wifi haha (bad I know) but whos gonna turn down free internet!
    Feb 2013
    Quote Originally Posted by jacquesy90 View Post
    I take it your neighbour doesn't know then. You should be ok as long as signal is strong enough. You just won't be able to record to usb stick as usb slot will be running the wifi dongle
  5. The Following User Says Thank You to meganecc55 For This Useful Post:
    jacquesy90 (29th December, 2013)
    Sep 2008
    You should be fine using wi fi then as long as you have a strong signal from your neighbour
    Dec 2013
    It has about 8-11mbps connection speed. will this be quick enough?
    May 2012
    That will be ample.
  9. The Following User Says Thank You to DW190 For This Useful Post:
  10. #8
    Dec 2013
    No, its an unsecured network for some reason...
  11. #9
    middots3's Avatar
    Feb 2009
    Middlesbrough
    It's not essential no, using ethernet certainly makes things easier though by freeing up the USB port at the front.
    I have a box in my bedroom using the wifi dongle and it's a pain when i install new channel lists etc, but that's life.
    F3 box ran terrible on WIFI though, F3S runs sweet.
  12. The Following User Says Thank You to middots3 For This Useful Post:
