Page 48 of 48 FirstFirst ... 38434445464748
Results 706 to 718 of 718
  1. #706
    Read EIS then press "Get EZS password"in order to do so you will need IR reader. When you have a key pass you can Virgin EIS by inserting IR reader to it.Then you proceed with manual.Yes I know AVDI's manual is really vauge.
  2. The Following 4 Users Say Thank You to QBAelectric For This Useful Post:
    Aniskey (23rd May, 2016), Aniskey2 (24th May, 2016), MV auto (23rd May, 2016), wiseman (29th August, 2016)
  3. #707
    Apr 2016
    Has anyone used the Simon Touch OBD option to connect and write to an EIS successfully? I am getting a USB error and Serial Number Not Found error. Application validates license fine, but it will not connect to car, or think the OBD cable is actually present.
  4. #708
    i_shot_the_sheriff's Avatar
    Nov 2008
    Hey mates,,,, as for avdi ,, im trying to make an ESL EMULATOR for w204 ,,
    1) I read FBS/DAS data + PASSWORD ok ,,,
    2) connect emulator on car
    3) Read emulator ok ,, VIN : 00000000000000
    4) Click Personalize and i get a fault saying EZS should first be not activated and then i must personalize ESL ! Should i make EZS virgin? Like clicking the virgin button????! After that the 3 working keys will work again?!
    I'm talking with support too ,,, but i'm in a kinda hurry and i'm not getting any fast responses today
    Thanks in advance
  5. #709
    Birmingham
    I dont know about AVDI, but with most tools you when you Virginise EIS, you need to write saved data with password back, then personalize ESL then activate
  6. The Following User Says Thank You to MarkPRP For This Useful Post:
    daxxer (8th August, 2016)
  7. #710
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by MarkPRP View Post
    Read the eis over obd, save data, read coding and save it too. Then make it virgin, yes.
    Personalise the esl emulator on it and write back the readed eis data that you got first, then coding and youre done.
    Yes all keys will work agai but you have to insert them first in the eis to get synced again
    Quote Originally Posted by i_shot_the_sheriff View Post
    Thanks in advance
    Sent from my SM-N9208 using Tapatalk
  8. The Following User Says Thank You to Mario3 For This Useful Post:
    i_shot_the_sheriff (8th August, 2016)
  9. #711
    Nov 2008
    Quote Originally Posted by Mario3 View Post
    I wonder why on the w204 manual section they don't say it that simple!! I really appreciate the explanation...... will do it tomorrow morning
    Sent from my SM-G930F using Tapatalk
  10. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    Mario3 (8th August, 2016)
  11. #712
    Nov 2008
    Done these steps:
    1) Read EZS + Password all ok and save on folder
    2) Put ESL emulator on car
    3) Click VIRGIN EZS and make ezs new
    4) Click Personalize ESL ,,,, now it says DONE !! ESL EMULATOR PERSONALIZED
    5) Go to EZS ,,, click PERSONALIZE with old files i saved ,,,,, click WRITE CODING (says written but with some ERRORS !)
    6) Put keys one by one in EZS and initialize ,,,,, and now DASHBOARD comes ALIVE !!! But car no start
    I've tried everything ,,, NO DTC ,,, dash open ok ,,, car no start ! EZS activated , personalized ,,,, but on the top it says EZS is neutralized
  12. #713
    Aug 2010
    Hi 8
    have original AVDI and AMS with man 0026
    also IR Adapter
    Check IT on a Viano MJ 2009
    in DAS MANAGER. I can Read EIS the i Put the IR ADAPTER OVER THE APROG ( You sea IT only in Video That You have to use the APROG together ) in the EIS
    BUT AFTER 1 MINUTE
    POPUP : Abritus dont work the Mercedes soft still Stopp
    any Solution to Read password by a Viano Up 2008 ?
    and also Need a Solution for Read the EIS ON Dash with one big MCU ( Rossfar have no picture for this )
    thmx
  13. #714
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by JFR-Tuning View Post
    Hi 8
    also IR Adapter
    BUT AFTER 1 MINUTE
    thmx
    Post picture of eis pcb and somone will give you a pinout
  14. #715
    Aug 2010
    Exclamation
    the First Problem is solved
    abrites forget to unlock MN025
    i buy now MN026
    second i Order the cable from MB KEY for x-prog i will Tester and Report
  15. #716
    Aug 2015
    Hi 8
    also IR Adapter
    BUT AFTER 1 MINUTE
    thmx
    What you mean with SW stopped?
    A error message or crashed programm??
  16. #717
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by offsystem View Post
    i think there is MCU mask: 0L01Y, no problem to read MCU eeprom with R270, VVDI Prog or other tools...
    many thanks to friend kevfield
  17. #718
    dave11674's Avatar
    Florida, UK
    Sorry to drag this up
    but where can we buy new blank NEC. Chips from
    for ESL. And keys
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
