please can i get pin code from this opel steering collumn 93c76
As far as I know Opel Antara / Chevrolet Captiva dose not have any pincode
yes the code 0508 was accepted,but key programming always fail why,i have gone to the car,the correct car name is opel signum 2.2 direct,the problem is that all keys are lost,i used 46crypt i cloned with zedbull,or must new ecu be replaced after key loss?year is 2005/2006,please and please help me
Keys without radio channel won't be programmed.
what is radio channel?the original remote key with three pressing pad is available,is only the transponder chip that got lost,though the remove is not working,please help.if i virgin the ecu will it start?
I don't know that still to advise you... But the ECU shouldn't be touched!
P.S. radio channel = remote
So Antara = Signum in your acceptation?
Signum = Vectra C in my acceptation and only accepts original remote key with Pcf7946 inside.
Your chip could not be lost because is on the key board.
So you have a defective key not a lost chip.
you are correct,what is the solution? can it be corrected and how?but if i press the remote is shows red light.can another used remote be programmed or it must be new?
i think u need oem key for vectra c or key allready use and change pcf 7946 then u make precod with zb. ans that it s all
next time check all detaills and then come and say what u need
