Hi all,
I seem to be having a problem getting the Dreambox 500s to lock and sync to the same satellite (Asiasat 3S) and frequency it which used to work before reflashing the image.
What i have tried;
Reflashing multiple images (Open PLi, Gemini 4.20, Commando 14.7) = no change
Moving the satellite a few degrees and back = no change
Tried a different frequency and symbol rate = no change
If this helps, (Currently cloudy had some rain last 24hr)
SNR - ~59-65%
AGC - ~55%
BER - fluctuates usually from a low # to high to low, etc
Reason for the reflash was due to the box being stuck on the permanent green L.E.D., blank screen, remote didn't work, etc.
I've reflashed the image to Gemini 4.20 as that was the one that came with the box when i first turned it on, as well as put in a satellites.xml file that was generated from here (satellites.xml generator / transponder .ini generator)
Thanks in advance
