Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: 2nd box looped
    Nov 2012
    Default 2nd box looped
    Hi guys
    im looking to setup another box upstairs
    Downstairs will be an F5s & upstairs will be an F3
    i have an input TV ariel port down stairs & an output TV ariel port upstairs
    Can i just connect the cable from the F5s loop to the Tv ariel port then connect a cable from the Tv ariel port to F3 box upstairs?
    If i do this would i still need to connect an ethernet cable to the second box upstairs?
    Thank for any help given
    Paddi23
    Hadron's Avatar
    Nov 2012
    E. London
    If you connect the boxes that way, then you can only have 1 box on at a time, as they will be fighting over control of the LNB.
    Also, you may get a lot of loss through the Aerial ports. The cable may not be suitable for satellite signals if ordinary, cheap cable has been used. Also the aerial sockets might not be connected together directly. They should be connected to a splitter or a distribution box somewhere, so the signal may not get through anyway.
    The second box will still need an ethernet connection.
    Apr 2013
    It will work but as already said the boxes won't work properly as you can only view either H or V channels at the same time.
    IMO it would be better to run a 2nd proper Sat cable from the LNB to the bedroom or to were the aerial feed for the bedroom originates from.....Sat cable isn't that expensive nor is a Dual/Quad LNB if needed and the end result would be much better by having 2 fully independent systems........LAN cable / internet feed to both.
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    run a second cable from dish to receiver and avoid the crying and gnashing of teeth.
    The loop out was for test equipment and not for connecting a second receiver.
    Nov 2012
    Thanks for the replies lads
    i can run the cable from the dish easy enough but getting the ethernet cable to upstairs is a pain in the ass
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by Paddi23 View Post
    Use a pair of Homeplugs (powerline adapters).
    I have used these ones in the past with no problems:-
    Buy ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit | Free Delivery | Currys
    Apr 2010
    manchester
    why not use the wifi on the one upstairs your f3
  8. The Following User Says Thank You to anno 1366 For This Useful Post:
    Stew2b (17th January, 2014)
  9. #8
    Nov 2012
    I didn't know the F3 had wifi
  10. #9
    Nov 2012
    These actually look good, can you get more of an extension for 2 rooms?
  11. #10
    digicon's Avatar
    Jul 2009
    If your question is regarding the HomePlugs then yes you just buy another set of the same brand and speed and you have another 2 rooms you could equip
  12. #11
    Nov 2012
    Quote Originally Posted by digicon View Post
    Cheers mate, i just didnt quote the reply
    Thanks to hadron
  13. #12
    Nov 2012
    Quote Originally Posted by Hadron View Post
    Thanks Hadron
    I have ordered these from currys (if i cant use them for this i willl use them for my sons xbox)
    I do have another question
    Im sure i read on here you can not connect 2 boxes to the 1 sat cable, i did read a post of yours in dojopros thread
    P&D...the no signal fix is for when you are using 2 satellite boxes on 1 LNB. I think dojopros wants to use 1 skybox with 2 TV's.
    The bold part got me thinking why is there a fix if this can't be done?
    I was going to try this http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
  14. #13
    Nov 2010
    Thanks Hadron
    I see you have bought the homeplugs, make sure upstairs and downstairs are on the same wiring loop, otherwise they wont work
  15. #14
    Nov 2012
    Quote Originally Posted by bobhope1 View Post
    Saying that mate, I don't think they are on my lecky box I have separate switches to turn off the sockets upstairs & downstairs (shit)
    Sent from my GT-I9195 using Tapatalk
  16. #15
    digicon's Avatar
    Jul 2009
    The Home Plugs will work the only time they dont is if you have something like a another ring main which is not looped into the first one, As for the Splitter that is not advisable at all to connect 2 sat receivers to the same cable each box should have its own feed from the dish
