does the box start again if you turn it off and on
again with the switch on the rear panel, if yes and
the remote still does'nt work, have you tried other batteries? if yes and you know the batteries are ok point the remote at the box and press and hold button 2 and 7 at the same time until the top left button flashes red and stays red then press the info button until it also flashes the button then type via the remote 0 0 0 2 and then click>ok
and then see if the remote works, i say this because if you got the box plug and play the remote could have been set on anouther number the default for the uno is 2
