In this topic we can share our experience with 2013.3 version.
Alfa romeo 147 2003 engine code 937.A2 can't connect to ecu unknown ID, other systems ok.
I have problems with connection to JTD engines from begining - usually unknown ID.
Faraday (4th May, 2014)
HYUNDAI ACCENT (00-02) Can't display Graph of any current data
H? all , Autocom,Delphi can't connect with ECU engine toyota corolla petrol 1.8 16v 1ZZ-FE , only ABS,ASR
ECU engine is DENSO , no connection, no response from controller.
Iveco Daily 05 problem to connect with airbag ecu
Autocom 2013.03 > Porsche panamera is no longer there.
my autocom work perfect on all cars
People Please post what kind of hardware do you use !
thank"s in advance
BR
My work is my life ART TECH GARAGE
whats the most reliable version? A friend had a Golden Version with OKI Chip, supposedly at the time, the best version, and he couldn't code injectors on a Renault Laguna...
Golden Version with OKI Chip is old m8 , pro is ok
when you say ok, what do you mean ? Can you code injectors with it for example ? can you do adaptations of components ?
What "Pro" version is this? Is that old one ? or new ? 1 pcb or 2 ?
I bought 4 (golden Pro 2 pcb with blue tooth) (1 for me and friends) and have no problems!
All on a EEPC with Windows 32 bit system.
When people say, without problems, i ask: What functions of the tool did you use ? Just read trouble codes ? Also erase trouble codes? Or did you also try to codify/adapt any new/changed component? Because this last one, is the hardest part... Codify injectors, etc...
From what I've seen, I still have to find someone who says this works fine, because I don't know anyone who has done it ok. Seams like clones cannot do it ?
cdp pro (gold) 2013.1 with wurth wow and delphi
work fine for me, diag + dct erase + adaptation
injector coding 1.5 dci renault clio + megane (delphi)
injector coding PSA edc16c34
