Page 1 of 2 12 LastLast
Results 1 to 15 of 24
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Default Autocom 2013.03 Experience.
    In this topic we can share our experience with 2013.3 version.
    Alfa romeo 147 2003 engine code 937.A2 can't connect to ecu unknown ID, other systems ok.
    Jul 2012
    I have problems with connection to JTD engines from begining - usually unknown ID.
  3. The Following User Says Thank You to lukash3 For This Useful Post:
    Faraday (4th May, 2014)
    Nov 2009
    grce
    HYUNDAI ACCENT (00-02) Can't display Graph of any current data
  5. The Following User Says Thank You to johnnts200 For This Useful Post:
  6. #4
    Jul 2009
    H? all , Autocom,Delphi can't connect with ECU engine toyota corolla petrol 1.8 16v 1ZZ-FE , only ABS,ASR
    ECU engine is DENSO , no connection, no response from controller.
  7. The Following User Says Thank You to jo?o antonio For This Useful Post:
  8. #5
    Jun 2010
    Iveco Daily 05 problem to connect with airbag ecu
  9. The Following User Says Thank You to gargamelc For This Useful Post:
  10. #6
    tiguan's Avatar
    Sep 2009
    Autocom 2013.03 > Porsche panamera is no longer there.
  11. The Following User Says Thank You to tiguan For This Useful Post:
  12. #7
    Mar 2014
    croatia
    my autocom work perfect on all cars
  13. #8
    mexanico1971's Avatar
    portugal
    People Please post what kind of hardware do you use !
    thank"s in advance
    BR
    My work is my life ART TECH GARAGE
  14. #9
    Jul 2013
    whats the most reliable version? A friend had a Golden Version with OKI Chip, supposedly at the time, the best version, and he couldn't code injectors on a Renault Laguna...
  15. #10
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Golden Version with OKI Chip is old m8 , pro is ok
  16. #11
    Jul 2013
    when you say ok, what do you mean ? Can you code injectors with it for example ? can you do adaptations of components ?
    What "Pro" version is this? Is that old one ? or new ? 1 pcb or 2 ?
  17. #12
    dopsleutel13's Avatar
    Aug 2009
    Dutch
    I bought 4 (golden Pro 2 pcb with blue tooth) (1 for me and friends) and have no problems!
    All on a EEPC with Windows 32 bit system.
  18. #13
    Jul 2013
    When people say, without problems, i ask: What functions of the tool did you use ? Just read trouble codes ? Also erase trouble codes? Or did you also try to codify/adapt any new/changed component? Because this last one, is the hardest part... Codify injectors, etc...
    From what I've seen, I still have to find someone who says this works fine, because I don't know anyone who has done it ok. Seams like clones cannot do it ?
  19. #14
    Jan 2011
    cdp pro (gold) 2013.1 with wurth wow and delphi
    work fine for me, diag + dct erase + adaptation
    injector coding 1.5 dci renault clio + megane (delphi)
    injector coding PSA edc16c34
  20. #15
    Aug 2009
    Dutch
    Quote Originally Posted by Tecno View Post
    I think you have e cheap + clone ? am i right ?
    Have seen more complains but always bad + clones !
