hi there got an original eurovox red reciver when i try to update the firmware with the correct firmware for this box it comes up with firmware not fit for reciver,any help would be great ty
Its one of two things, one it is not a red (2007) model or two it is the wrong firmware. Also check to see if its a clone or genuine model.
its genuine red 2007 checked the best i can,took lid off looked inside got me beat at mo ty for quick responce
Which firmware have you tried? Have you tried blue firmware also?
plus ive downloaded the red firmware
UFL_MAX_RED_30_11_08
As above have you tried blue?
yes pal the same happens
If you are 100% sure that it is definitely a red, try earlier firmware revisions. They will not AU but see if they flash and then we can go from there.
tryed every red firmware will not load same message,the box is in standbye mode stuck on now but i boot up and get message if u know what i mean,hard reset
is there a original firmware that might reset to source??
or a dnumpman file??
silver front 99% sure its a max red
If the box is stuck with the red standby light on, it is then a capacitor problem and not a firmware one.
Is this the case?
all was ok till i tried the firmware download capacitor is 100% ok
box was on just not auto update
