Results 1 to 7 of 7
    dimitar's Avatar
    Default peugeot 307 hdi edc16c3 dpf off
    need dpf off on this one ,,,Ecusafe and Volta dont work
    ecu edc16c3 0281011234 thanks
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    digi men's Avatar
    Nov 2013
    EU
    hy here you have,try and report
    pass in pm
  3. The Following User Says Thank You to digi men For This Useful Post:
    dimitar (15th January, 2014)
    dimitar's Avatar
    thanks mate i had the same solution like edc16c3-9 but i wasnt sure if it works or not, thanks again
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    digi men's Avatar
    Nov 2013
    EU
    no problem, i help if i can Sometimes whit Hammer
  6. The Following User Says Thank You to digi men For This Useful Post:
    dimitar (16th January, 2014)
    dimitar's Avatar
    another problem now i also need egr off and related dtc off if anyone can help
    dtc like p0400,p0405 etc. etc. the egr is broken in half ,,,,,never ending piece of french garbage i guess its hammer time
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  8. #6
    dimitar's Avatar
    OK can anyone remove dtc codes please
    p0405
    p1462
    p1351
    thanks in advance
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  9. #7
    dimitar's Avatar
    bump bump
    50w Soldering Iron
    Chisel
    Sometimes Hammer
