friend has to read flash, for dpf off
here you have, try and report
pass in pm
enrikass (2nd March, 2014)
not good not power
do you have any Dtc ?
what is the dtc?
I can do it On Ols just pm bro...
Winols,Swiftec,Ecm Titanium, Kess V2, Ktag, Portugal Fg V54, Powergate, Byteshooter, Beeprog...
do you have some diagnostic toll, like lexia diagbox, to read the fault code on car ?
dtc is fault code (P441) so luck a code, that tell you wat is wrong with car, iam not shure that the flash is not good, because it is the standart switch off for this ecu, maybe you have some other trouble, do you have make all good befor you have use the file, i mean prepared the car ?
I have autocom.but as the signature ecu. autocom.do not read
we can try another dpf off solution and if needed also i can try dtc removal, if interested in, please pm
