Results 1 to 12 of 12
    Oct 2013
    Default VW Tiguan EDC 17 CP14 DPF remove...HELP
    Hi guys,
    Ive been pulling my hair out trying to remove DPF.
    Cant get it right...need some brains and a decent file to load..PLS HELP
    Nov 2013
    Europe
    send me original file.
    Chiptuning files, DPF/FAP off, EGR off, DTC, IMMO, etc.
    Oct 2013
    Thumbs up
    hope its done correct...let me know..thanx in advance
    digi men's Avatar
    Nov 2013
    EU
    here you have
    pass in pm
    Oct 2013
    thank you digi men, no luck though...
    ive tried several files with no success...
    Nov 2013
    Quote Originally Posted by darrynf View Post
    I hope this can help you.
    Senior Member Diagnosticated's Avatar
    Mar 2011
    What is problem. Your file looks like simple single switch required so a mod file should work ok.
    Nio's Avatar
    People that posts no good files with pass. I have never understand this.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
    digi men's Avatar
    Nov 2013
    EU
    When you mean my file , i must to say you are wrong, it is 100% ok
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
    Dec 2013
    Tested manual solution. You just let tool to calculate CKS.
    Tiguan_dpf off- 394195.rar
    Pass in PM.
    Oct 2013
    Hi guys, still no luck as of yet...ive resorted to getting another vehicle just incase...will keep you updated.. Thanx
    digi men's Avatar
    Nov 2013
    EU
    Do you have made, before you flash the modified file reset all your Dpf data ?
    VCDS or Vas-PC and carry out the adaption that tells the ecu that there is a new DPF fitted. This will reset soot values and oil ash volumes to zero. That means once you flash Dpf off file there is less chance ecu will look to do a regen !
  13. The Following User Says Thank You to digi men For This Useful Post:
    NOUNOU1212 (20th February, 2015)
