try the newer image
http://www.digital-kaos.co.uk/forums...00C-test-image
try the newer image
how do you add auto autobouquet to a image??
Look here but remember the rules http://www.digital-kaos.co.uk/forums...Bouquets-image
Education is not the learning of facts, But the training of the mind to think
So hit the thanks button if I have enlightened you.
Make sure your attributes sre 755 after transfer
try blue button
maybe commando toolbox .not at the box now
just make sure its active in there........Paul
PAUL
WOODWARD395 (17th September, 2015)
This is the first time using Enigma 1 is there anything else I should be aware of doing a first install anywhere Thanks.
discovered one of my files was corrupt from a bad download on my previous problem but still not there yet.
Thanks for your help plasterer much appreciated as said totally in the dark as to why it wont work the box is faulty or just one simple setting, its so annoying
as it only takes me 10 to 15 mins to setup my Enigma 2 box if that from scratch. Thanks again.
on reading similar posts I think although it states all is well with network connection and my other box DM800HD connects fine, what would be the best image to try with every thing installed for a test.
I have used network plugs and wireless adapter now I will purchase a 30mtr cable this week just trying to eliminate anything and everything.
Just flashed this image http://www.digital-kaos.co.uk/forums...Bouquets-image and used same files and up and running totally baffled to why as exactly same setup as on commando.
Another problem you get is when an online re-flash is done and you try to use autoboquets it will not work have tried several times with same results.
The image is working great on my DM500S clone and is a great image yet for some unknown reason will not work on my original DM500S baffled.
WOODWARD395 (20th October, 2015)
